Ticking after Start up????
allmost sounds like an exhaust leak.
i would double check the rockers are all torqued down to spec and didnt come loose on you.
installing the oil pump seal incorrectly would create little to no oil pressure which in turn would cause the valvetrain to be noisey...check your oil pressure.
hope this is of some help to you..
rick
SAAAAAME exact problem I am having. I have it at the shop right now. I just installed the MS4 cam with heads and new ewp and I have the EXACT same problem.
My guy thinks it is the pushrods being the wrong length. Maybe we need 1.735 not 1.74's? We will see.
I will let you know what the heck the problem is when I find out.
What length pushrods did you install?
If you aren't losing oil pressure (keep an eye on it) your pushrods may be a smidge too short so when the aluminum block/heads expand they start making noise.
