Cam Install What Else Should I Do While It's Apart?
Old Nov 24, 2006 | 12:17 PM
tamikews6's Avatar
Default Cam Install What Else Should I Do While It's Apart?
Ok I just bought the tr224/224 lsa114 cam package
1 CAMPK-S Thunder Racing LS1 Cam Swap Package $599.99 $599.99
Gaskets: No Gaskets
88-VSR103-T Retainers: Titanium Retainers $129.99 $129.99
Year: 2001-2005
99-TR224/224-114 Cam: 99-TR224/224-114
Thanksgiving Sale -$73.00 -$73.00
I also won a SLP double roller timing chain off of ebay. Is there anything else I should put in while the car is some what apart? I was thinking underdrive pullys but I have heard they are more of a hassel then they are good. Also do I need to replace the gaskets when installing a new cam or can I get away with just replacing the harmonic balancer bolt? I have about 5k on the engine. Thanks for the help.
Old Nov 24, 2006 | 12:39 PM
Wheeler99WS6's Avatar
Ive heard of some people upgrading their oil pump while doing cam swap.
Old Nov 24, 2006 | 12:44 PM
tamikews6's Avatar
Is anyone familar with CA smog? Would I have a chance at all passing smog with the tr224/224 lsa 112? I just placed the order so I am sure I could still change it.
Old Nov 24, 2006 | 07:20 PM
GR33N GoblinM6's Avatar
better have a great tuner...
Old Nov 24, 2006 | 07:45 PM
Mssingkid's Avatar
Oil Pump ( Have to take it off anyhow)
If 98-> 99+ Water Pump Gaskets If 99 and no cuts, ok to re-use
Front Seal (Depending on how many miles you have, if you re-use it you'll leak)
I'd also get a UD Pulley since you have to remove the stocker anyhow.
Old Nov 24, 2006 | 08:02 PM
Phantompooper's Avatar
The 224 cam is the biggest smog-legal cam you can use. Provided you program out the random cylinder misfire code. I do recommend the oil pump since half of everything you need to remove is going to be off anyway.
Old Nov 24, 2006 | 10:47 PM
six8fbird's Avatar
Hey I am not motto but hip hip hooray for the marine thing. I am stationed out on Marine Corp base Hawaii. Unfortunately I also have to put up with smog laws of Cali, let me know how this cam works out for ya. If your results come out better than expected with the smog regs than maybe I will go steeper, who knows! Well, take it easy fellow teuful!
Old Nov 25, 2006 | 01:47 AM
tamikews6's Avatar
So yes with the gaskets, UD pulley, and oil pump. Any cheap websites?
Old Nov 25, 2006 | 02:07 AM
SmokeySS's Avatar
Is it 114 or 112 LSA? You said both.
Old Nov 25, 2006 | 02:12 AM
mvvette97's Avatar
I may be wrong but doesn't he have to machine something on the damper so the double roller will fit?
Old Nov 25, 2006 | 10:36 AM
tamikews6's Avatar
I called and changed the orig 114 to the 112. Any info on the install of the double roller would be great. I have some buddys that are going to help me but the are all mopar guys. I was also stationed at MCBH. I lived right across from the golf course. Get some devil.
Old Nov 25, 2006 | 11:28 AM
Mssingkid's Avatar
*I* think double rollers are overkill for a street car app. If you use the search engine there have been a few guys that have broken the double roller (Only seems to happen to M6 cars and seems to be a harmonic issue) I can't recall reading a single thread of anyone breaking a LS2 chain. You can use the difference towards the UD Pulley... just my .02c
Old Nov 25, 2006 | 12:04 PM
2000Hawk's Avatar
I just installed my MS3 and put in an LS2 Timing chain i don't think with what your installing your going to need a double roller, but if it helps you sleep better at night then its all on you. I also got the TSP Ported LS6 oil pump, i see it as your already there so you might as well.
-Joel
Old Nov 25, 2006 | 12:55 PM
tamikews6's Avatar
What does a LS2 chain go for? How much can I get for my slp double roller? I paid $95 for it.
Old Nov 25, 2006 | 03:19 PM
Mssingkid's Avatar
I paid 35.99 from Texas Speed for the LS2 chain. As long as the Double roller is NIB i'm sure you can get close to what you paid for it... if not return it...
Old Nov 25, 2006 | 05:22 PM
Blk97WS6's Avatar
-Joel
exactly what im going with when i install my cam next week.
Old Nov 25, 2006 | 05:24 PM
2000Hawk's Avatar
You can't beat a ported Ls6 pump and LS2 chain. They are both priced very well and its extra insurance if you have a high miled LSx engine.
-Joel
