P0300 code
Old Dec 13, 2001 | 06:32 PM
Tom99SS's Avatar
Default P0300 code
Will this code set a SES light? just curious.
- Tom
Old Dec 13, 2001 | 07:42 PM
SpeedDemon's Avatar
Default Re: P0300 code
Yup.
Old Dec 13, 2001 | 09:00 PM
Slick T/A's Avatar
Sure will
Old Dec 13, 2001 | 10:16 PM
Fulton 1's Avatar
Yup, P0300 is common in cammed cars. It's one I wish I had removed <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" />
Old Dec 14, 2001 | 06:32 AM
Tom99SS's Avatar
Thanks to all for confirming this. I just did not know as I had the DTC put no SES. Must have been stored. I have since cleared it.
- Tom
Old Dec 14, 2001 | 08:21 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yes, ditch this code if you ever get a custom PCM. My upcoming PCM will not have it either.
Old Dec 14, 2001 | 08:52 AM
Tom99SS's Avatar
Yep,
This winter, MTI will be getting my PCM for the upgrade. Got the car to idle around 700rpm. Used the Idle set screw and a small shim on top of the set screw. No idle codes so far so this is looking good.
Had the TB hole drilled out first then did the idle set screw fix. Car has a slight lope to it but sounds good. Great job by LS1Speed.
- Tom
