MS4, T-rex, MS3
you said you wanted over 234 duration... why exactly?
if you want a good power making cam that has a little lope then there's no need to go bigger than a mid-high 220's cam on a 112.
unless you just want it basically for the sound of a really mean ls1. then i'd say it's a waste if you don't plan on racing a lot.
if i had to vote on one though - i'd say ms4 on a 111
Yeah, the specs sound right on your buddy's car. Not sure what point you're trying to make though. Help me out a little. I'm a little slow today I guess.
I will have full bolt ons with 90/90 setup, yank pt4000 stall, 3.73 with true duals. This car will not the see the track that much if at all. What cam would you use. I have no problem adjusting to cams.
thanks everyone for your opinion.
By the way does anybody have sound clips on the MS4 i cant find then anywhere and i was considering buying one.
i would say both cams like the strip.
the ms4 is way bigger than you'll need for a street car that occasionally sees the track.
smaller cams create more torque at a lower rpm becuase of the lesser overlap. with that - smaller cams also produce better fuel economy.
smaller cam's LIKE the street, and street cars LIKE smaller cams.
