View Poll Results: stock lifters?
i replaced my lifters
39
23.64%
keep them in till they fail
16
9.70%
stock lifters XER lobes with 0-30k
47
28.48%
stock lifters XER lobes with 31k-60k
18
10.91%
stock lifters XER lobes with 60k +
20
12.12%
stock lifters LKS lobes with 0-30k
11
6.67%
stock lifters LKS lobes with 31k-60k
9
5.45%
stock lifters LKS lobes with 60k +
5
3.03%
Voters: 165. You may not vote on this poll
LSK & XER LOBES AND STOCK LIFTERS WHOS DOING IT
Old 01-27-2007, 06:21 PM
NoMoreFWD's Avatar
An article in Circle Track has a new nascar LS2 built by Carl Wegner. It's using stock lifters, spinning 8000 rpm and making 625 hp.
Old 01-30-2007, 10:42 PM
GrannySShifting's Avatar
125k miles and you want to use LSK lobes on stockers, your asking for trouble. Most of the guys running old lifters and LSK lobes that think they have no problems... are likely leaving power out there.
Old 10-27-2007, 09:12 AM
JPH
JPH's Avatar
questions: 1. cam profile?
2. valve spring being used? pressures, etc..?
3. how hard u going to turn the motor?
Old 01-05-2008, 08:40 PM
ABQ99TA's Avatar
I have LKS lobes and just tunred 60k I only have a couple grand on the cam but everything seems fine.
Old 01-05-2008, 09:06 PM
SOMbitch's Avatar
Not sure what your plans are but if you are gonna pull the heads for any reason it's a no brainer. Otherwise you might be able to get away with it. Some people have.
Old 01-05-2008, 09:37 PM
james562's Avatar
Zach@Texasspeed what were u using for fuel supply on your cammed sprayed 98 TransAm?
Old 01-05-2008, 11:34 PM
black01_WS6's Avatar
stock lifters, but when I do heads I will be replacing them with new ones.
I would reccomend new lifters for anyone doing a cam swap if they have higher miles.
Old 02-03-2008, 08:37 AM
98TA_vert's Avatar
My friend tried to get away with using the stock lifters on his 89000mi motor w/xer lobes only took a week for it to bite him in ***... for what you can get a set of LS7 lifters for its not worth the time to do it twice.
Old 02-03-2008, 10:32 PM
eamador11's Avatar
when i did h/c i had ECS replace my stockers with Comp Rs. 26k miles later and no issues!
i have the comp xer 224/228@114 cam
Old 02-05-2008, 08:43 AM
NOBR8KSS's Avatar
Just did a cam swap about 4 months ago. 125,000 miles on the stock lifters and I don't intend to swap them until I see bits of metal in the oil pan or until I upgrade the heads.
People say that the lifters are cheap...but after you buy lifters, trays, head bolts, head gaskets, and header gaskets, you are in for at least $5-600.
Cam is XFI lobed.
Old 02-05-2008, 02:04 PM
Asmodeus's Avatar
I have new stock replacement lifters (LS7). LSK intake lobe, XE-R exhaust lobe. 228/232 112+2. Engine had 95k at the time of the swap.
Old 02-05-2008, 02:14 PM
  #32
Zach@MTI's Avatar
If you are going to run stock heads (assuming you are staying with stock heads since you mentioned running LSK's on stock lifters) then there is no point in using LSK lobes other than it will wear out your valvetrain quicker....
If you plan on upgrading heads later then at that time you could upgrade to a better lifter thus justifying the LSK lobe camshaft now...
Personally either way I would not run an LSK lobe cam unless you have a larger motor with a stellar set of heads, that is really the only instance where I have seen a camshaft using those lobes make a sizeable difference.
Old 02-28-2008, 12:06 PM
  #33
yyz28's Avatar
Comp Stock Replacements on a MS4.
Old 04-20-2008, 04:54 PM
  #34
NemeSS's Avatar
ls7 replacements with lsk lobes
also have used ls7's with tr trex cam
Old 05-12-2008, 06:21 PM
  #35
01 MidMet WS6's Avatar
Where is the best place to get LS7 or Caddy racing lifters? Are they the same or does one have an advantage over the other? Thanks!
Old 05-12-2008, 06:30 PM
  #36
bayer-z28's Avatar
LSK, .640" w/ 200 miles on the stock lifters.. A little ticky, but fresh cam install with cheap synthetic oil for the first 500 miles.. Goin Back to Mobil1 or RP soon.. (Gonna try the RP, weekend cruiser)..
PatG Cam.. Two different lobes.. Can't find the card..
Old 11-20-2008, 08:06 AM
  #37
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
Stock Lifters.
Did heads & XE-R cam at 32,000 miles. Car has 110,000 miles on it now. So 78,000 miles on stock lifters w/XE-R cam.
Old 11-20-2008, 03:57 PM
  #38
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Normally, I'd make a necroposting comment but this is a good thread. I think a lot of people under estimate the stock lifters. With decently low mileage on them they work well.
Old 12-21-2008, 11:58 AM
  #39
99blancoSS's Avatar
https://ls1tech.com/forums/generatio...r-problem.html
Old 04-27-2009, 06:24 AM
  #40
SweetS10V8's Avatar
Im running Comps LSL lobes, they are more agressive then XER, but less than an LSK. I swapped to Comp 850-16s.
Quick Reply: LSK & XER LOBES AND STOCK LIFTERS WHOS DOING IT
