Oil coolers...
Old Dec 17, 2001 | 04:06 PM
Steve Underwood's Avatar
Default Oil coolers...
What is the best oil cooler kit available for LS1's. I sit in a lot of traffic sometimes being that I live in Houston area and my oil pressure will drop a little from getting hot. I noticed that the cat being so close to that oil filter is not help matters. <img src="images/icons/rolleyes.gif" border="0">
Old Dec 17, 2001 | 07:49 PM
Chris Spiess's Avatar
Default Re: Oil coolers...
I remote mounted my filter to get it away from the heat of the converter and to run a larger filter and increase system volume. I also installed a temp gauge while I was at it. I was originally planning to do a cooler, but have decided against it at this point after seeing the temps. I routinely run 180 or less around town, even in traffic in the summer; and level off around 210 on the highway at a steady 80-85. Neither temperature is anything to worry about w/ quality oil, particularly synthetic. I run AMSOIL 0-30 in the car year round. Think about installing a temp gauge first and see if youreally need to go to the trouble of a cooler.
Old Dec 18, 2001 | 08:18 AM
I'll try that. Which oil filter relocation kit did you use and where did you mount the filter assembly? <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 19, 2001 | 02:57 PM
Perma-Cool 4-port relocation block and spin-on adapter, Russell hose and fittings. Shoot me an email and I'll send you some pictures - don't have them on this computer right now - and I can get you a parts list as well.
