Learned a lesson the hard way about custom tuning...
[quote]Originally posted by RPM WS6:
<strong>I have a 180 t-stat, and they said that they would set the fans for a 180 t-stat, but I think what they actually did was set them to come on at 195 (that is the temp it got to on a-tap before it came on) and go off at 180. Problem is, my 180 stat isn't letting the motor get any cooler than 192.
</strong><hr></blockquote>
That's about right for a 180 t-stat. The car should run 12 - 14 degrees warmer than the T-Stat. When I had a 180, my car stayed around 192 - 194 degrees. With a 160 T-stat, you actually run in the 170s.
RPM WS6,
Thats really strange you had a problem with a core PCM. Last year I bought a '99 blank PCM from Shaun( ValveGod). I now have a '02 WS6 which I'm gonna need custom tuning when I get my heads/cam installed. Well at work I have the equipment to copy flash chips. So for *****&Giggles I copied the program from my stock '02 PCM into my blank '99 PCM. It works perfectly!! It now has over 100 miles on it and no problems. So by copying my stock program it copied everything inside it including the VIN#. It sounds like the MTI PCM was just bad. When I copied my PCM program I was able to review the data. The VIN# is the only number thats not in HEX format. So I was able to change the VIN# to something different and store the changes, then re-burn the chip.
[ January 01, 2002: Message edited by: 02BlackWS6 ]
[ January 02, 2002: Message edited by: 02BlackWS6 ]</p>
LS1Tech Premium Sponsor
Glad to hear everything worked out. MTI works really hard to provide the best service possible to its customers. Can't tell you how many times they've bent over backwards to help me out <img src="gr_stretch.gif" border="0">
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1Tech Administrator
Received 1,677 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
[quote]Originally posted by 02BlackWS6:
<strong>RPM WS6,
[ January 02, 2002: Message edited by: 02BlackWS6 ]</strong><hr></blockquote>
According to what Jayson said, it was an LS1 edit issue. I guess that software just doesn’t have the ability to change VINs yet. Either way, I would recommend that no one else take this chance if they have their stock PCM still available to them to use. Better safe than sorry, IMO. <img src="gr_stretch.gif" border="0">
Again, I do praise MTI for how they took care of me. Their a great company who will continue to have my support <img src="gr_stretch.gif" border="0">
<strong>RPM WS6,
RPM WS6, just wanted to add that you can still use your (if you have one) HPP3 to do your shift points while using LS1 edit. I actually had mine done at Thunder Racing (they use LS1 edit too) for $350 (don't know what MTI charges), then programmed the shift points my self. I agree with you on the TM <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Dan
Dan
[quote]Originally posted by Cool AirZ28:
<strong>RPM can you or did you get the fuel map changes through MTI?</strong><hr></blockquote>
Yes, they did their version of “power tuning” for the cam I chose.
[quote]Originally posted by DanZ28:
<strong>RPM WS6, just wanted to add that you can still use your (if you have one) HPP3 to do your shift points while using LS1 edit. I actually had mine done at Thunder Racing (they use LS1 edit too) for $350 (don't know what MTI charges), then programmed the shift points my self. I agree with you on the TM <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Dan</strong><hr></blockquote>
DanZ28...Thanks for that info! Jayson told me that he didn’t recommend using the HPP3 with LS1 edit, but glad to hear that it works. I might try it out and see if I can get my shift points up a bit if I need to, but I already have a buyer for it. It’s good to know that it can be used though. <img src="gr_stretch.gif" border="0">
TM is evil <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
