Learned a lesson the hard way about custom tuning...
I call MTI this morning and after telling them the situation I was informed that my order was the first time they had used a core PCM with their new tuning program (I’m guessing they mean LS1 edit). They said that as far as they knew the changing of the VIN went just fine during the tune, but that this must be the problem because A-tap wasn’t even recognizing a VIN. They said with their old tuner using a core was never an issue, but that it obviously seems to be now. So now I’m waiting for a final call back about what they want me to do, which is probably send them both PCMs and they’ll tune my stock one and just take back and credit me for the core that didn’t work. I really wish they had told me I was going to be the first so that I would have been expecting some issues, or just sent them my stock PCM to begin with.
So, to all of you who plan on having a shop with LS1 edit do your tuning, make them use your stock PCM and not a core, unless you want to take a gamble that what has happened to me might happen to you too.
I would highly suggest to any of you that are going to have an LS1 edit shop do your tuning to have them use YOUR STOCK PCM. At least until this “bug” is worked out. This is the reason why it sucks to be the first to have something done.
If MTI can actually pull this off and have my stock PCM tuned and shipped out to me tomorrow, then I will be very impressed and sing enormous amounts of praise to them. I know they have a good reputation, and I’m hopping it holds up. I’m going to give them the benefit of the doubt at this point and thank them for all the effort to get this resolved for me this quickly. Let’s hope it works out...
<strong>Man that sucks, hopefully you will get it straightened out soon.</strong><hr></blockquote>
Thanks for the well wishes <img src="gr_stretch.gif" border="0">
I hope LS1 edit doesn’t fail me again <img src="gr_sad.gif" border="0"> ...
Dave
Unfortunately, I’m stuck here at work and I won’t be able to install it till tonight. I’ll won’t have access to any computers over the holiday weekend, so I doubt I’ll be able to give a full report on the LS1 edit tune until after the holidays. I will post and let everyone know by Wed. next week. If by some miracle I happen to end up near some internet access over the weekend I’ll post sooner.
And yes, I agree that I would never try to use LS1 edit on my own till it’s been out A LOT longer...
i hope u see my point.. dont install the new computer until you have the new cam in.
i would think it should still start though.
make sure they know that the cam the computer is tuned for.. is not in the car.
<strong>hmm hold on a second... you sent a computer away for custom tuning for a cam.. and you expect it to run fine when the stock cam is still in the car???
make sure they know that the cam the computer is tuned for.. is not in the car.</strong><hr></blockquote>
They are well aware that the stock cam is still in the car. They said that was fine. Raising the idle and playing with the WOT fuel maps isn’t going to effect the way the car starts or runs at part throttle. When I a-taped the core it would not connect because there was a VIN discrepancy.
I’ll see if I can make some time to update you guys on the situation tomorrow morning...
All I have to say to guys that still have TM is, you are seriously missing the boat if you’re planning on a built tranny and don’t have TM removed. There is a world of difference in how the tranny behaves now. It’s not a “slush box” any more. I was getting negative timing on my upshifts though, so some of you who didn’t have it as bad as me might not notice as much difference, but to me it was huge.
Also besides your tach likely being slow, ATAP has a hard time measuring the 1-2 shift. Log only mph & engine rpm or just rpm. 1st gear flies by.
About the shift points, I didn’t do any logs, I just graphed the data in real time in Windows, which I know is probably slower. I should run a log on this at the track before I make any changes I guess...
Why didn't they use their old program to insert you VIN into the new PCM, then move to the LS1 edit system to do the actual programming? Surely they are creative enough to think of that.
But tell me, What are all the changes you had done to the ECM? I'm tired of TM and I'm sending mine in next week to have it done too. Let me know what things I should do to the ECM As you know I have the A4 and the SY3500 <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> The SY3500 Really rocks.
Waitin' for your reply....
Thanks Ryan
I talked to Dave at Carputing about LS1EDIT and it's ability to change the VIN. He said that LS1Edit will not allow you to do this. Also he said I would have to make sure the PCM came from a LS1 Camaro and not a Truck/other vehicle, or I would have to get a dealer to re-flash the PCM with the propriatary GM flash file on a Tech-II. I called the dealer and they said I would have to tow the car in with that computer in it, then pay them $400 to flash it. So $400 + Towing... I paid MMS to tune the computer for me and got it done now instead of waiting for LS1Edit which was supposed to be out in August 2001 (Riiiiiiiight, Glad I didn't hold my breath).
The farther I look into LS1Edit and the more questions I ask I am finding that it is rather limited.
Oh, and BTW, 90% of all the PCMs you see for sale out there are either "blank spares" or default with "Truck Programming" accoding to Shaun (ValveGod@AOL.COM). If you're looking for a spare he's the guy to see, his pricing and attitude are awesome.
[ December 22, 2001: Message edited by: HalfMoon ]</p>
To answer your question, what you have done to your PCM really all depends on what you’re planning for your car. I had my idle raised for the cam, PO300 misfire code removed, B1 cam specific WOT “power” tuning, shift point changes, fan temps changed, rear O2s removed, EGR code removed, and some other small stuff, plus the TM being removed.
My best suggestion to you is to contact a tuner like MTI and tell them what you plan for your car. Then go over with them what they think you need and what you would like to do. The price is the same if you have 3 changes or 20 changes, so get everything you think you want as the price is the same.
I would like to say again that MTI did a great job once they got the proper PCM, and they took care of me great when this problem arose. I would recommend anyone to use MTI for tuning; just remember to send them YOUR STOCK PCM.
