370ci
Old Nov 27, 2006 | 09:10 PM
Big Bird WS6's Avatar
Default 370ci
what is a 370. what does it start as 5.7 , 6? iron, aluminum? and do i bore it? please help
Old Nov 27, 2006 | 09:35 PM
wildta's Avatar
370 is a iron 6l block bored .030 over using stock crank
Old Nov 27, 2006 | 10:04 PM
1999 SS's Avatar
what would be the cubic inches of a 5.7 346ci motor be i it was bored over .30 and running the stock cranck?
Old Nov 27, 2006 | 10:07 PM
DONAIMIAN's Avatar
You cant bore the 5.7 aluminum block that far over, most is .010 and that makes it a 348.
Old Nov 27, 2006 | 10:08 PM
GR33N GoblinM6's Avatar
well considering you shouldnt bore ANY motor .30 over.... i think you mean .030 over..
LS1 aluminum engines should NOT be bored.. they are sleeved.. and you can not take .030 off of the sleeve on an LSx based aluminum engine. i think I have seen some one mention that the biggest you can take it to would be .010 over... if that.. and most people wouldnt even do that.
Old Nov 28, 2006 | 08:11 AM
SSdreamz's Avatar
not to hijack this thread but, all the kits that i look into call for a 3.905 bore and a different crank(347,474, 383) now im talking building a stroker engine. but i measured my cylinder walls and came to the conclusion that i need to machine out .0074. can this be done safely with no worries?
Old Nov 28, 2006 | 08:12 AM
PREDATOR-Z's Avatar
usual is 3.905 bore max on 99+
