SLP LT's and a 100 shot???
Old Dec 19, 2001 | 08:23 PM
badazz99ls1's Avatar
Default SLP LT's and a 100 shot???
would this lean my car out to the point of it blowing up by adding headers and the y-pipe. Mods are in the sig.
lookin' for low 11's <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Dec 19, 2001 | 08:30 PM
2002SS's Avatar
Default Re: SLP LT's and a 100 shot???
That combo will be fine as long as you get some tuning.
Cartek has a timing tricker in which they pull some timing from your engine when the nitrous is applied. You may want to give Dave at Cartek a call.
www.cartek.net.
Dan
Old Dec 20, 2001 | 09:59 AM
Jax White TA's Avatar
I have that setup with a Hammer cam and pulled 473RWHP and 557 ft lbs TQ WITHOUT tuning. I also have the HPP3 with non RFG tuning to bump the timing up. My knock retard flashed to 1.3º once on the dyno when the y pipe banged but other than that the timing was around 27º on the juice with no knock retard. This is a 100HP dry shot spraying through a single nozzle into the MAF. Headers richen up your car.
Old Dec 20, 2001 | 03:46 PM
Country Boy's Avatar
Senior Member
Im pulling around 700 RWTQ with these headers and a 200 wet shot so i have no problems.
Old Dec 20, 2001 | 04:06 PM
BlackSuperSport's Avatar
Long tube headers will make you run richer which is a good thing when running nitrous. As long as everything is installed properly you'll be fine. <img src="gr_images/icons/wink.gif" border="0">
