m6 Idle speeds
Old Dec 5, 2006 | 10:44 PM
Ryan02SS's Avatar
TR224 112 925rpm Makes a nice short chop but takes a gearhead to notice thru the cats. Car is also smoother with the higher idle not shaking much.
Old Dec 6, 2006 | 02:03 AM
5w20's Avatar
MTI B1 cam
700-750 RPM idle. Can't really tell theres a cam there. Must be the stock exhaust manifolds and y-pipe.
Old Dec 6, 2006 | 09:05 AM
eamador11's Avatar
Originally Posted by Regginator
224/224 on 114 lsa @ 1050-1100rpm
bought the car with the cam so idk why its set to idle so high
bad tune!
Old Dec 6, 2006 | 10:07 AM
8GTOKLR's Avatar
216/224 .551 115lsa with rhoads lifters idles at 650rpm. In 1st, clutch out and a little on the brake the car will pull itself at 400rpm
Old Dec 6, 2006 | 10:10 AM
dbhajek's Avatar
I have always wondered about aluminum flywheel affecting idle especially with a bigger cam.
Originally Posted by DONAIMIAN
Most people here with aftermarket cams set the idle to 900 anyway. Also the weight of the flywheel and clutch will affect how the car idles. FWIW I have a 221/221 on a 112 with an aluminum flywheel and all it does is surge with anything less that 900rpm.
Old Dec 6, 2006 | 11:12 AM
2003torch's Avatar
233/239 600 605 at 850 rpm idle.
