What is wideband tuning?
Old Dec 23, 2001 | 02:44 PM
Allen's Avatar
Default What is wideband tuning?
Never seen it before? Is it plugged in like the Tech II or what?
Old Dec 23, 2001 | 03:24 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: What is wideband tuning?
Wideband tuning is typically done on the dyno, where the shop has a wideband air/fuel gauge that is put in your tailpipes and gives a very accurate reading of the air/fuel ratio. If the shop has tuning software (i.e. LS1 Edit), changes can be made to the tuning to get the air/fuel where it should be.
Jason
ForbesSS's Avatar
When I had my car dynoed, they used a wide band meter. This device uses tail pipe emmisions to determine the precise air/fuel ratio. From what I understand, the O2's on your system aren't accurate for A/F monitoring.
