valve Job angles?
Old Dec 23, 2001 | 10:28 PM
TA2SLOW's Avatar
Default valve Job angles?
Stage1 or Stage2 heads guys.....are you using 30*,45*,60* degree cuts or something else for your valve jobs?
Old Dec 24, 2001 | 08:36 AM
TA2SLOW's Avatar
Default Re: valve Job angles?
I quess nobody knows
Old Dec 24, 2001 | 10:07 AM
turbo's Avatar
The only thing I heard of is 3, 4, 5 angle valve jobs. Now I just had my heads cleaned up and the guy said he was doing a 5 angle cut on mine.
I guess theres different terms for the job..
Casey
Old Dec 24, 2001 | 10:31 AM
TA2SLOW's Avatar
Some one has to have played with different angles?
The old small block chevy 23* heads use the 30,45,60 degree cuts.....but with the 15* LS1 heads I would think the cuts would be different as the valve sits straighter in the bore.
Anyone?
Old Dec 24, 2001 | 11:16 AM
Crazyquik's Avatar
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=1&t=000529
This link might help you a little bit (but probably not much).
J.
Old Dec 24, 2001 | 07:11 PM
TA2SLOW's Avatar
Yeah that isnt telling me anything!
I want to hear from some pro head porters what they are using?
I already talked to someone that use to work for GTP and he told me that changing the angles a little steeper will improve flow.
[ December 24, 2001: Message edited by: TA2SLOW ]</p>
Old Dec 25, 2001 | 10:00 AM
wizkid's Avatar
Install Director
You are going to have to call the porters and ask on the telephone. I wouldn't think (could be wrong) they are going to broadcast it on the board. You might be surprised to what shops really know what angles they are too.
ERic
