Size of Plug on the pass side cyl. head next to #8?
-Josh <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
You'll need to get a M12x1.5 to 1/8th adapter. I got mine from Equus at autobarn.com. It was like 5 bucks. I didn't actually end up doing it there anyway, my arms just aren't skinny to get to that spot. I ended up using the freeze plug that is directly above the starter. With putting headers in, you should have room though.
Dope
Its an 8mm Hex to remove the plug in the cylinder head.
I got the same adapter as Dope to replace the plug and use along with my Autometer sender. I gave it a quick try this weekend to install it, but like Dope I couldn't quite get to the plug very easily. I have very skinny arms though, so I when I have more time I will give it another shot. It looks like you can reach it from the top by removing the back 2 coil packs, or from underneath.
<strong>It's M12x1.5.
Dope</strong><hr></blockquote>
Dope can you be read specific about this freeze
plug mod.. did search and did not find much.
tia Terry
