TRex cam with nitrous possible?
Old Dec 1, 2006 | 02:23 PM
mulletwearingtadrive's Avatar
Default TRex cam with nitrous possible?
Could you run a big *** cam like the TRex with a shot of nitrous? say a 75 shot? If not what is the biggest cam you can run to make good power(over 400+rwhp) with a 100-150 shot of nitrous?
Old Dec 1, 2006 | 02:46 PM
sciff5's Avatar
supposedly there is no problem running nitrous with the TREX unless your running a large shot, 200+, and then there are rumors that you get diminishing returns after that. a 75 shot is nothin though dont worry about it. You can spray a 75 shot with pretty much any cam.
Old Dec 1, 2006 | 03:05 PM
wow....thats cool. So a TRex with a wet 100-150 shot wouldn't be a problem?
What about tuning? How would you tune the car to get the maximum power out of the cam NA and still work well with nitrous?
is the TRex streetable? LOL
Old Dec 1, 2006 | 04:21 PM
97BlackLT1TA's Avatar
I would say you are fine with the 150 shot. As far as streetable, that depends on what your definition of streetable is. With the proper tune I think you would be ok.
Old Dec 1, 2006 | 04:23 PM
The1N_only's Avatar
the only reason why they say not to spray a big shot on the t-rex is because the cam has a lot of over lap and would bleed off some of the juice
Old Dec 1, 2006 | 04:26 PM
slick1851's Avatar
Im going to with trex, and wanted to know the same thing good thread
Old Dec 1, 2006 | 04:27 PM
slick1851's Avatar
My car isnt a daily driver
I would suggest going with the MS4 cam for more of a every day car, but you can def daily drive a T rex, its all in what you like etc
I dont see any problems with it
Old Dec 2, 2006 | 05:48 AM
where can you get the MS4 cam and what are the specs?
Old Dec 2, 2006 | 10:42 AM
mcamarols1's Avatar
www.texas-speed.com
Old Dec 5, 2006 | 11:21 AM
My car currently has 3.73s and is a six speed......would those gears be ok with a cam like the Trex?
Old Dec 5, 2006 | 11:28 AM
turbo'd stang's Avatar
We've sprayed 200-250 on that cam. Did just fine. i would suggest a standalone fuel system if you are using a wet shot.
Old Dec 5, 2006 | 11:29 AM
Would I need a standalone with a 100-150 shot? What about running just a 75 shot until I can upgrade the fuel system?
bad95killer's Avatar
peace
Old Dec 5, 2006 | 11:35 AM
So would it be ok to stick with a 75 or 100?
01350ss's Avatar
It is highly recommended by thunder to run AT LEAST 4.10 gears. If your going with nitrous I would stick with the 4.10's. I have the trex cam, 90mm intake and throttle body, 85mm maf and lid, z06 heads, built t56, and a 9" with 4.57 spool. I love to drive my car on the street. It is a wicked ride. Very driveable in my opinion. I have an awesome tune through vette doctors. The car put down 480 through the 9" and has absolutely no cam surge even at 1500 rpm in 6th. I get in and turn the key and she fires every time. I have been throwing the idea around about going nitrous as well and have no fear of doing it. The only thing I would change would the gear ration in the rear. 4.57 gears on nitrous would probably be to much gear for nitrous down the track. I may go to a 4.30. By the way I'm running a 28" slick on the track
Old Dec 5, 2006 | 11:36 AM
If possible I would like to stay with my 3.73s so if I get the cam I will see how it feels with my current gears and then change to 4.10s or 4.30s if necessary
Old Dec 5, 2006 | 11:52 AM
The1N_only's Avatar
yeah that would be fine... i wouldn't spray to much over a 150 shot, but it wouldn't hurt anything if you put... lets say a 250-300 shot. Its just that cam has a lot of over lap about bleed a bit off and if you went with something that was a little bit tighter you would benefit more when you fed your car the dope. and i would go no less then 4.10's(auto) or 4.30's(M6) and thats on the juice. If you stay N/A i would go no less than 4.30's if you have a 4l60 and 4.56's if you have a t56
Old Dec 5, 2006 | 11:55 AM
I already have the bottle so I won't ever be completely NA I guess. I want the car to be strong off the bottle as well....
Old Dec 5, 2006 | 11:58 AM
The1N_only's Avatar
Just make sure you have the drivetrain that can take some abuse from the 7000 rpm launches
Old Dec 5, 2006 | 12:03 PM
lol....I have some suspension mods and a better clutch hopefully on the way soon with a flywheel.
Will I be ok on the stock rear end as long as I don't run sticky tires?
