Pro Touring Cam?
Old Dec 27, 2001 | 03:34 PM
smokin' joe 00 ss's Avatar
Default Pro Touring Cam?
I've been doing alot of research on all the post of different cam's and it seem's that most have the 1/4 mile in mind, but I would like to keep this Hot Rod like a Pro Touring ride good off throttle responce and when I want to grab some gear's it's got good power up top too. I like to take the car on some trip's and hit the curve's in the Mountain's and Ilike the 1/4 mile once in awhile too, so I guess I'm saying I would Like good idle with a little thump to it But I need it reliable for those longer trip's. Any idea's on which cam would be a big help, Thanks <img src="gr_stretch.gif" border="0">
Old Dec 27, 2001 | 03:51 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Pro Touring Cam?
A lot of what we do is friendly for Pro Touring.
A lot of our sponsors' cams are very good for all-around performers.
BIGBOS's Avatar
do a search, there has been a lot of talk about cams recently... <img src="gr_stretch.gif" border="0">
Old Dec 27, 2001 | 04:05 PM
[quote]Originally posted by BIGBOS:
<strong>do a search, there has been a lot of talk about cams recently... <img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
Yea I know there has been alot of talk lately, I've done a search and read alot it just seem's most people are into the 1'4 mile and i'm more into both but I guess I would like it to be more of a road car, I've had alot of 1/4 mile car's in my time with big block's and thumpy cam's but these new SS with great gas milage seem more like a Pro Touring ride to me <img src="gr_images/icons/cool.gif" border="0"> so many cam's to chose from <img src="gr_grin.gif" border="0"> just wondering if anyone has set up their ride like this and what cam they went with. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 27, 2001 | 04:09 PM
LS1Tech Co-Founder
I haven't followed Pro Touring that close, can you be more specific in what changes/enhancements you want to your car?
Old Dec 27, 2001 | 04:44 PM
LS1powerN20's Avatar
i do some closed circuit racing occasionally and the hotcam does an awesome job, I wasn't expecting anything great from it on the road course, but i must say i was very impressed. the hotcam is a cam that has excellent response from 2000rpm - 6500rpm and makes awesome power through the entire rpm range, it would be that much better with long tube headers, which i don't have yet <img src="gr_sad.gif" border="0">
Old Dec 27, 2001 | 05:27 PM
ChrisB's Avatar
You might check out the cam TrahnZham (on this board) has - I think it's a very mild cam, though I guess on here it would be considered a medium range one. 223 degrees of duration - his is on a 112 I believe, 114 would give a little better idle. 418rwhp@5800rpm - 411ft-lbs of torque with a hydraulic roller! I think it would be a killer street grind!
Chris
Old Dec 27, 2001 | 07:07 PM
[quote]Originally posted by Pro Stock John:
<strong>I haven't followed Pro Touring that close, can you be more specific in what changes/enhancements you want to your car?</strong><hr></blockquote>
Pro Touring is really the all around car that could run coast to coast with no problems with the air on or off good gas milage and can dive into the curves and have great throttle responce coming out of them and still have good power for the 1/4 mile. So with the mod's I have in my sig beside's a cam i want to install I plan on putting in 3.73 gears and a Z06 clutch set up and a BMR torque arm and a LS6 intake. So I guess I'm looking for that all around cam thats a good reliable drive that makes good power. I'm a GM employee so I could get a great deal on the Hot Cam from the GM warehouse but I'm not to sure about how the 112 lsa would be for a good idleing cam, or should I try and go with a special grind?
[ December 27, 2001: Message edited by: smokin' joe 00 ss ]</p>
Old Dec 28, 2001 | 06:10 AM
[quote]Originally posted by ChrisB:
<strong>You might check out the cam TrahnZham (on this board) has - I think it's a very mild cam, though I guess on here it would be considered a medium range one. 223 degrees of duration - his is on a 112 I believe, 114 would give a little better idle. 418rwhp@5800rpm - 411ft-lbs of torque with a hydraulic roller! I think it would be a killer street grind!
Chris</strong><hr></blockquote>
Thanks Chris, I'll see if I can find him on the board and check it out. I'll also check out the B1,C1,and T1 cams too, they are so close together it's hard to tell which would be the all around better street cam.
