TSP 200CC heads/Fast 90/90 question
#81
Originally Posted by Jeremiah
Someone earlier said epoxy was a thing of the past, thats not so. Several serious engine builders still use epoxy to alter/repair ports ect. I would get with Fast before I used epoxy on there intake though. The epoxy has shown reliable on metalic sufaces but what about the plastic material. I would be concerned with it eventally sepperating from different expansion characteristics and being sucked into the backside of the valve or even into the cylendar.
Originally Posted by caseys103
There are several way you could go about that project. I know several people on this thread were opposed to the use of epoxy.But, I have successfully used Z-Spar 788 Splash Zone (green death) epoxy for years. If it were me that is what I would do.
Casey Snyder
Cylinder Head Instructor
School of Automotive Machinists
Casey Snyder
#82
If anything the epoxy will probably work better on the plastic because it doesnt hold heat like the aluiminum does. Just a little speed tip for you guys: The Fast two piece manifold is prone to internal leaks, which, costs some power. I recommend sealing the seams with RTV silicone. I have seen over 15 horse gains.
Casey Snyder
Casey Snyder
#83
Casey Snyder
Casey Snyder
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
