Blown head gasket?
Old Jan 3, 2002 | 07:58 PM
SLowETz's Avatar
Default Blown head gasket?
Changing oil tonight...open filler cap to find a few droplets of water on the underside of cap, and some trace amounts of white looking jizz on the inside of the filler neck. Doesn't "look"
like antifreeze, but does feel the same
if rubbed between your fingers. No droplets on dipstick...didn't notice any in the old oil
(wasn't really looking though),....no smoke out of exhaust, and tips are dry. WTF???????
Could a "small" amount as described be considered "normal" condensation?,...
or should I pull the V.covers and have a look?
Thought it could've been from the rocker bolts that are now into the water jackets, but put
what I thought was a very liberal amount of thread sealant on the bolts.
REALLY don't wanna pull the heads...AGAIN,......gonna do a vacuum check
tomorrow to see if that shows any fluctuations/low readings, but so far does
this sound like a blown head gasket?
Can I drive it with fresh oil while watching the cap/stick until I come to a conclusion, or
should I nut up and pull the heads tomorrow night?
Mike
'00WS6/M-6
I/H/C with the usual bolt ons
Old Jan 3, 2002 | 09:33 PM
dand35th's Avatar
Default Re: Blown head gasket?
Thats it, just condensation. I have it on my truck as well, more often when its cold outside.
Old Jan 4, 2002 | 01:25 AM
minty's Avatar
either that or it REALLY is JIZZ in there LMAO <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
Old Jan 4, 2002 | 06:30 AM
Plan B's Avatar
[quote]Originally posted by SnakeKiller:
<strong>Thought it could've been from the rocker bolts that are now into the water jackets, but put
</strong><hr></blockquote>
The rocker bolts, into the water jackets??? nah! most ported heads break into the intake port. That's OK... Just pressure test the water to about 12-14psi sit and watch... if the guage drops quickly.... you've got probs... otherwise, go and have some cold air fun <img src="gr_stretch.gif" border="0">
Old Jan 4, 2002 | 09:20 AM
NC Guy's Avatar
It probibly is just condensate, but why take a chance on it.
In addition to pressure testing the cooling system as has been suggested, I'd do a cylinder leak-down test as well. If it is a bad head gasket, at least you'll know which side has to come off.
Enjoy your cars.
Old Jan 4, 2002 | 10:57 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Clean it.
Don't pull anything.
For the next three mornings, pop off the radiator cap. Top it off the first day. Start the car, top it off until the t-stat opens. Might get a bit messy. If on the 3rd day you are still topping it off you might want to pressure test the cooling system. I was adding like a cup of coolant every day when I had a blown headgasket with the old motor.
Old Jan 4, 2002 | 04:26 PM
SLowETz's Avatar
Thanks for the input guys...I figured it was just some cold weather condensation, but hadn't seen that on this motor yet....guess I prematurely freaked at thought of pulling the head/s again.
DUHH!!!!....haveing some fuel smell in the oil issues which was on my mind when I made the post.
Thanx again guys!
Mike B.
'00WS6/M-6
