Oil level on dipstick?
Old Dec 6, 2006 | 10:49 AM
BLKWS.6's Avatar
Default Oil level on dipstick?
Okay...this one is kinda dense, but someone told me the oil level on the dipstick when filled to factory spec in an LS1 F-bod is in the MIDDLE of the
addXXXXXfull -----
Part of the dip stick, say on the middle X. Is this true, or should it register on the "full"
Old Dec 6, 2006 | 10:54 AM
2000LS1TA's Avatar
I always put mine on the full mark, oil is cheap, parts are expensive.
Old Dec 6, 2006 | 11:09 AM
SoCalZ28's Avatar
Ive heard that too, just like the normal point on most of our gauges are in the middle... I fill mine to full though cause,
Old Dec 6, 2006 | 12:40 PM
BLKWS.6's Avatar
I do too, 6qts. I was just wondering where "OEM" should be. How much does it take to hit the "full" for you guys? 6qts puts me in the middle of the ---- above "full"
Old Dec 6, 2006 | 02:35 PM
TheLS1Kid's Avatar
just changed my oil this past saturday. 6qts did it for me
Old Dec 6, 2006 | 02:58 PM
dnm12's Avatar
5.5 quarts is what it says in the manual
Old Dec 6, 2006 | 03:09 PM
BLKWS.6's Avatar
Where does your oil level sit on the stick?
Old Dec 6, 2006 | 03:11 PM
blkbird's Avatar
At 5.5 quarts my level is right on the full mark.
Old Dec 6, 2006 | 06:07 PM
SoCalZ28's Avatar
depends on the oil filter size your using too
Old Dec 6, 2006 | 11:10 PM
BriancWS6's Avatar
With the factory size filter and 5.5 quarts it will be dead nuts on full (top X) If you are like me and run the longer K&N filter (PN HP2006) with 6 quarts it will be right at full, or maybe a very small amount over.
Old Dec 7, 2006 | 10:23 AM
black_z's Avatar
I run 5.5-6 with the shorter filter.
