Santa came early! My TEA TFS LS1 Heads/cam/intake package is here!!!!
#42
Originally Posted by getusum
https://ls1tech.com/forums/showthrea...wpost&t=619807
I have the same heads..mine actually flow 343@600 and that came from LME not TEA..look at last months gm high tech...5 heads, 5 independant results, tea 225's out flowed afr 225's by 19cfm...that was from gm high tech...look at my sig, my #'s don't lie...trust me, you'll love these heads....
Here's the article. Read it again.
http://www.gmhightechperformance.com...ads/index.html
getusum, do you actually have a flowsheet from LME and not TEA, and what kind of flowbench does LME use?
#43
Originally Posted by Brian Tooley
Well, if our Flowdata shows an AFR 205 to flow 300 cfm, does that mean it really flows 240-255 cfm? Cause that is what an AFR 205 flows on our bench, and 240-255cfm would be the 15-20% you speak of.
The pipe does add about 10-15 % on a GOOD exhaust port, the pipe will cause a bad exhaust port to flow less.
I think he bought the heads based on the 500 RWHP they have made on a couple different dynos.
The TFS 225 flowed 324 intake on a superflow bench and the exhaust numbers were off by 30cfm.
https://ls1tech.com/forums/showthrea...ht=AFR+205+225
#45
Arguing about TFS vs AFR is really silly. They are both great heads. I'm sure I could have gone with AFRs with same results. Bottom line is, it's time to enjoy these things!
#46
Kleeborp the Moderator™
I'm thinking someone needs to do some pruning in this thread to clip out some of the uncalled for negative comments. That looks like an incredible stack of parts there...wish I had the money this year to do that Soon enough I suppose...keep us updated on the numbers when you get them
#49
Originally Posted by JRracing
Here Jeff. Check out this paint job I did on my 90. It is from TEA as well. Very nice peice!
[/IMG][/URL]
[/IMG][/URL]
#52
Originally Posted by Cobraeater
The TFS 215 outflowed the AFR 205's by 9cfm.
#53
The AFR head in that test was a 225
The article says a 205cc AFR head was used. Here's some quotes from the article.
[GMHTP]
Their LS1 Mongoose (prepared for this test to run on an LS2 engine) is no exception. The 2.02/1.60-inch intake/exhaust valve arrangement combines with a 205 cc intake port for a delicious combination of high velocity and big flow.
AFR
* Name AFR LS2 Mongoose
* PN 1510
* Price $2,479.99
* Combustion Chamber size 66 cc
* Intake Port Size 205 cc
* Valve Sizes (intake/exhaust) 2.02/1.60 inches
[/GMHTP]
Also here's the thread you started about the GMHTP Head Shootout.
https://ls1tech.com/forums/showthrea...&highlight=TFS
A TFS 215 against an AFR 205, even Tony Mamo was curious what a AFR 225 would have done in the test.
Originally Posted by Tony Mamo @ AFR
What would a set of AFR 225's done on this same engine ?? (that would have been interesting...)
#55
Originally Posted by Blue Meanie
Why do AFR fans ALWAYS have to come into threads about TEA TFS heads and have to throw ****. It is getting OLD!
"Hello hater hot line, how may I help you?"
"Yeah, Yeah, I just can't stop hating today....matter a fact I've been hating pretty much all week"
"Did you wake up this morning and drink yourself a tall glass of hater-aid ?"
crap that's funny. who knows, anything over 450 and I'll be happy.
#57
Originally Posted by jeffstar
That looks sharp dude. Yeah things went really well so far.
I am a body shop owner, so it was pretty easy for me.
First. clean it with soap and water. or rubbing alcohol and dry it quickly.
Then use a spray can plastic primers. Then the color. Let dry for a while then clear it.
The next day come in and hand paint the logo's as desired. It took about 2 hours total. And waala!
Jeff. I would almost bet 1K it makes 450+ HP.
#59
I think the TFS heads are some of the best heads out there ( The best LS1 heads TEA has ever produced.) along with ETP and AFR, but I don't like the inflated numbers off a different type of flowbench that Tooley uses.
jeffstar, based off your before dyno numbers you should hit 450rwhp easily maybe even 480rwhp. Good Luck!
#60
Same reason people keep telling me my car can't make over 450 rwhp. Some are skeptical but many don't want to see a H/C car make what their stroker car did (peak numbers only of course).
