Stupid pick-up tube bolt! Help!
Im tring to get this stupid pick-up tube bolt out. Ive been going at it for about 30 min now. my question is how freakin long is this damn bolt?? ive been turning and turning with a gear wrench and i wont come out! the threads dont feel stripped or anything, it turns easily, but it seems like this thing never ends. i can see where the pickup tube is dropping, and it is loose, but it seems like its not getting any looser. Whats the deal?
and what do you mean dont use a wrench. how else are you supposed to get that thing out. theres no way to get a socket on it. besides im pretty sure the bolt isnt stripped because the threads feel fine.
-Joel
Yes!! This cannot be stressed enough. I ended dropping it about 3 time before i got the first couple of threads in there. But dont forget to get those rags out once you are done. Then youll have worse problems!!!
I know it...im gunna spend as much time on getting this damn bolt in and out them im going to spend on the rest of the cam/spring/chain/oil pump swap.
