Help! When turing the crank......
it is probably just your entire rotating assembly...it doesnt have fresh oil all over it , as that has probably drained or ran off completely...and since the car has been sitting..nothing is warm..so youre going to hear some noises, there is a lot of crap going on when an engine turns...
Its probably just your paranoia of things going wrong which is 110% NORMAL! Everyone faces it...if you had a serious problem, the engine wouldnt turn at all...or would be very difficult to turn...sounds like this is not the case for you...get it done and fire her up
