Well its final - My Cartek S2 LS6 H/C info is here!!!
Old 01-10-2002, 10:28 PM
JS
JS's Avatar
Default Well its final - My Cartek S2 LS6 H/C info is here!!!
I talked to Julio this afternoon
We chatted about my Mom (She's Dying) and he gave me his blessing.
I ask him ALL the BS I needed to about the setup.
I'm not doing a stroker or big bore ANYTIME soon. (Tony I wont bother u ANYMORE)Its not $$$ friendly to my setup as of now.
Julio does the LS6 S2 heads for a 3.90 Bore
Not gonna redo the heads as of now
I'm gonna do a 346CI N20 short block later for the car and hit the button...
Here r the CARTEK specs:
STOCK untouched short block 346CI
LS6 S2 Heads w/11.5CR
Ported LS6 Intake
224-224 580-580 113LSA Cam
PTB w/LS1 Edit'd PCM/30Lb Injectors
Dynatech STEPPED headers w/3in collector
3in ORY into 3in Single exhaust/Cutout
4L60E w/Yank TP4400
12-bolt 4.10's
Hope to make 420RWHP w/the combo threw a 12-bolt,auto trans shifting right at 6700rpm.
I'll be adding the Hals,K-member,A-arms,manual rack down the road to lighten her up alittle over the summer.As of now my car weighs over 3550lbs w/ME in it and after the 12-bolt it'll be even heavier.
JS
Old 01-10-2002, 11:03 PM
2002SS's Avatar
Default Re: Well its final--->My Cartek S2 LS6 H/C info is here!!!
Other then the headers and the suspension upgrades, that combination sounds mighty familiar <img src="gr_stretch.gif" border="0"> hehehehe
I will be getting my car back at the end of next week hopefully. Just waiting on the 150 shot nitrous setup, 12 bolt Moser rear with 4.11s, line lock, and Autometer tach w/ shift light to be installed. The 12 bolt should arrive tomorrow hopefully.
Good luck with your setup. Let us know how it does.
Dan
Old 01-10-2002, 11:52 PM
02BlackWS6's Avatar
2002SS,
Nice setup.Do you have any NA times with your setup?
Old 01-11-2002, 02:00 AM
Mike Hoffpauir's Avatar
I say with your weight 11.00's no problem.
3300 pound raceweight 10.80's for sure.
Maybe these are conservative guesses?
Goodluck JS =)
Old 01-11-2002, 02:03 AM
ls1fun's Avatar
[quote]Originally posted by JS:
<strong>Here r the CARTEK specs:
Ported LS6 Intake
4L60E w/Yank TP4400
12-bolt 4.10's
JS</strong><hr></blockquote>
Sounds like an awesome setup!
Just take your time and tune it right!
Best wishes,
Ron
Old 01-11-2002, 09:15 AM
LS1 Tech Administrator
Patrick G's Avatar
Everything looks great except for the y-pipe. You should really consider a 3 1/2" y-collector going all the way to a 3 1/2" cut-out, then necking down to 3" right before the axle. THAT would be ideal. The area of a 3" pipe is only 72% the area of two 2 1/2" pipes. A 3 1/2" pipe on the other hand, is within 2% of the pair of 2 1/2" pipes. Make sense?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 01-11-2002, 09:21 AM
Patrick G's Avatar
I just noticed that you have twin 3" pipes after your headers...guess you'll need a single 4" pipe to a 4" cutout to work best, huh?
__________________
Old 01-11-2002, 09:30 AM
JS
JS's Avatar
Patrick I'm gonna run a 3in Y to 3.5in intermediate to 3.5in cutout.
Then back to 3in over the axle and to 1 DYNOMAX 3in Round Race Magnum to one 3in Tailpipe.I feel this will flow well enough w/o weighing TOO much.
I'm gonna also have Mufflex make the Y pipe quick release so I can try open 18in collectors from time to time.
I've done some ET calculations and I should run in the 11.15 to 11.05 range w/this setup at MY weight.
JS
Old 01-11-2002, 09:34 AM
Patrick G's Avatar
Now THAT'S what I'm talking about.
__________________
Old 01-11-2002, 09:47 AM
Ragtop 99's Avatar
<img src="gr_images/icons/cool.gif" border="0">
When will it be ready?
Bring it to cecil and I'll do the light driver mod and put you in the 10s. <img src="gr_images/icons/wink.gif" border="0">
Old 01-11-2002, 10:00 AM
JS
JS's Avatar
Rag,I can put u in the car and technically say I was driving.My name is Joel too. <img src="gr_grin.gif" border="0">
ANYTIME u wanna make a pass in the car and I'm at the track u can buddy.
Good Luck w/the ARE setup
U r gonna fly .....
JS
Old 01-11-2002, 11:24 AM
Terry Burger's Avatar
JS sounds good. I wonder if the LS6 heads and longtubes will be worth much over your last setup? When will the car be together?
Old 01-11-2002, 11:50 AM
JS
JS's Avatar
Will find out soon Terry.
FWIW my JPR S1 setup dynoed 374.9RWHP/359.6RWTQ
I hope to Dyno in the 410 to 420 range w/the Cartek setup?Will it ET better,Who knows but like I said,We'll find out very soon...
JS
Cartek 346CI N20 short block comming soon w/Duel stage dry setup w/Speed Pro SEFI <img src="gr_images/icons/wink.gif" border="0">
Old 01-11-2002, 11:52 AM
GeorgeC's Avatar
Sounds good, but one thing I don't like...
The stock untouched shortblock and 6700rpm shifts. I'm gong to make a post later with some details/info which will shed some insight into some things going on with my car... For now let's just say it is not in very good shape right now. My stock crank/rods/Wiseco pistons bottom end didn't live under similar conditions, and it was even balanced. IMHO, much more reliable than a stock untouched shortblock. I have a lot of work to do now due to what appears to be a failure in the bottom end. No way would I try to put big HP to a stock LS1 bottom end again...
If you have the opportunity, at least upgrade the pistons and rods, and have everything checked and balanced.
Old 01-11-2002, 03:58 PM
So JULIO is going to get you a CUSTON cam for the juice?
Old 01-11-2002, 05:12 PM
JS
JS's Avatar
Yea terry its a new design
Called CUSTON <img src="gr_images/icons/wink.gif" border="0">
Come on Buddy give me a break
I type to fast
JS
Old 01-12-2002, 12:06 AM
JS
JS's Avatar
Thanx George I totally agree...
6600-6700 should last alittle while til the N20 short block is built
Prepped block
N20 Piston w/lower ring land
File Fits setup for N20
Lunati Billet Rods
Stock Crank
Steel Caps
ARP Bolts
Balanced
ATI Balancer
I would think this will be VERY STRONG.
I really wanna run a 2 stage Dry setup w/a SEFI controlling everything.
JS
Old 01-12-2002, 12:37 AM
CHRISPY's Avatar
Good Job Joel!
I would go bigger on the cam though <img src="gr_stretch.gif" border="0">
You are getting custom PCM work so why not take advantage of it <img src="gr_stretch.gif" border="0">
A nice 226/228 cam on 112LSA would be awesome NA and spray <img src="gr_stretch.gif" border="0">
Cheers,
Chris
Old 01-12-2002, 12:54 AM
JS
JS's Avatar
Chris after the short block is done JULIO will get a CUSTON grind done for the spray setup
JS
Old 01-12-2002, 02:52 AM
ls1fun's Avatar
<strong>Yea terry its a new design
I type to fast
You type to fast ____what?
Oh, i see , you type too fast! <img src="images/icons/rolleyes.gif" border="0">
Just pulling your leg! <img src="gr_images/icons/wink.gif" border="0">
As for rpm, don't a lot of people set the limiter to 6600rpm with the hypertek and shift just before that?
