I am having some problems
Well i changed out the cam and have the new one back in, but i cannt get the harmonic balancer on. I went and got the install kit but the bolts are to small. Any thoughts? <img src="images/icons/confused.gif" border="0">
Use your old bolt to "push" it back on. Make sure that the crank snout is clean and lubed lightly with clean oil. Same for balancer. Tighten bolt to ~250 ft/lbs. Buy a new bolt, torque to 37#'s and then tighten another 140°.
