Dyno test...Lost 35 RWHP
3 months later I tested 297 RWHP and 312 Torque.
I noticed a loss of SOTP immediately after my Air Conditioner compressor was repaired because it burned out. Since the compressor rebuild, my revs are not as loud nor as crisp when I rev on someone.
My wife said I am puffing black exhaust out the tail pipes when I WOT'ed in 1st. I've also been advised that the insides of the y-pipe cat converters are damaged a/c their insides rattle.
My questions are....
- Could my air pump have gone bad again (it got water in it once)
- Improper repairation of the Air conditioning compressor (since there is now a noticeably increase of RPM loss whenever I switch on the AC
- Could the AC mechanics have banged up my cat converters while doing the AC repairs and guts of the cats flopping around are restricting exhaust flow
- Could bent valves cause the black exhaust and loss of SOTP when WOT
ThanX
Man thats not a good story... <img src="gr_sad.gif" border="0">
<strong>During a previous day at the dyno, I tested 334 RWHP and 341 Torque.
ThanX</strong><hr></blockquote>
Definitely sounds like the wrench-monkeys fu(ked some **** up <img src="gr_images/icons/mad.gif" border="0">
Its normal for you to see rpm change when ac comes on, youll also feel a rev difference when compressor is running. Also ac comp. shuts off when you get into the throttle, so even if comp. is not exactly right, you shouldnt blame that.
If your converters are broken you can bang on them and hear if there loose inside. Last why do you think you might have bent valves?
