SLP header install
Old Jan 11, 2002 | 11:57 PM
blackssmagic's Avatar
Default SLP header install
Well i have the starter off and the motor mounts, the car is a 99 so what is the trick, in the bottom if so how. I am going to give it a try in the morning again so thanks.
Old Jan 12, 2002 | 01:52 AM
Mike K.'s Avatar
Default Re: SLP header install
you have to have it high enough off the ground and then unbolt the tranny cross member, then push the tranny to the side a little and they should slide right in.
Old Jan 12, 2002 | 08:01 AM
TA_2001's Avatar
This should help you out..
http://ls1info.com/article.php?sid=149
and a few notes
http://ls1info.com/modules.php?op=mo...=34&forum=3&12
[ January 12, 2002: Message edited by: TA_2001 ]</p>
Old Jan 12, 2002 | 04:54 PM
JaSSon00's Avatar
no need to take the motor mounts out, just get it really high and take the crossmember out and they WILL slide right in.
Jason
