What thread type / pitch are the LS1 headbolts?
Old Dec 11, 2006 | 05:45 PM
jeffstar's Avatar
Default What thread type / pitch are the LS1 headbolts?
Reason I ask is I have 2 complete Metric and SAE tap and die kits.
I could probably chase the bolt holes with the right tap if I knew the size....
SAE (size/pitch) or METRIC (size/pitch)
Anyone know?
Old Dec 11, 2006 | 06:30 PM
chopperloco's Avatar
Default Do Not Use A Tap To Chase!!!!
It is metric(11mm i think)but use a thread chaser!
A tap will cut fresh threads and weaken them,then you are more likely to "lift" a head/blow a head gasket.
Dominic
Old Dec 11, 2006 | 06:39 PM
ROCNDAV's Avatar
It wont be in your set. THe bolt is an 11mmx2mm if I remember correctly. You can call around and hardly anyone will have one. I think the cheapest that I found it was for $75 pus shipping. THe thing that eveyone does on here is to use an old (long) head bolt and grind a slot on one or two sides of it (like tap would have) and use it to clean out the holes.
Old Dec 11, 2006 | 07:04 PM
ls1 joe's Avatar
ARP has thread chasers for ls-1s
Old Dec 11, 2006 | 07:20 PM
jeffstar's Avatar
Love this board. Everytime I'm thinking about doing something really stupid this community saves my ***. Thanks guys. I guess I'll use the old cut a notch in the stock head bolts.
