All the cam and header guys come in
Old Jan 13, 2002 | 09:52 PM
blackssmagic's Avatar
Default All the cam and header guys come in
I have SLP long tubes the driver side went in with no problems but i cannt get the passenger side in all the way. I have the heat shield off and starter but still not enough room. Any ideas? Also i did a cam swap and cannt get the damn harmonic balancer on at all. The bolt isnt long enough to use that to get it in. I am lost with this so thanks for the help. <img src="images/icons/confused.gif" border="0">
Old Jan 13, 2002 | 11:13 PM
TA_2001's Avatar
Default Re: All the cam and header guys come in
Pass side first.. then drivers side..
Yes I know that is not what the instructions
have.
http://www.ls1info.com/article.php?sid=149
Ok the crank pully.. I got a bolt that was about
one inch longer with the same thread style from
Elliots hardware and started the pully then switched to the new bolt.. went right on.
Old Jan 14, 2002 | 01:26 AM
Supertrapped's Avatar
Speed freak
Undo the passenger side motor mount and jack the engine up a little. That should give you enough room to put the header in <img src="gr_stretch.gif" border="0">
Miah
