Timing @WOT only at 25?
Old Jan 13, 2002 | 10:50 PM
CWK's Avatar
CWK
Default Timing @WOT only at 25?
I was wantig to know the effect of this low timing on horsepower? Jayson @ mti said with custom tuning he could set the timng @30. How much horsepower gain from timing and the tuning.
Old Jan 14, 2002 | 08:13 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Timing @WOT only at 25?
Do you have an ’01 or up? 25 deg. At WOT on ‘01s and up is normal. You don’t need as much advance due to the redesigned cam profile.
Old Jan 14, 2002 | 09:28 AM
rom3's Avatar
I would agree with what RPM WS6 said. I had a '99 T/A and would get 28+ degrees advance. I atap'd my '01 the first month I got it and got a max of 25 degrees (around 5,700 rpm). Thought maybe it would go up after break-in but it did not.
Old Jan 14, 2002 | 09:34 AM
Nine Ball's Avatar
LS1Tech Co-Founder
To answer your question, we need to know all the details about your car. If its stock, then you won't gain much. If its highly modified, you will gain power.
More info please!
Tony
Old Jan 14, 2002 | 09:38 AM
LIL SS's Avatar
Moderator
Just to let you know, my 01 gets 25.5 @ 5900-6k and thats with lid, filter, bbk, gmaf, maft, cats removed, exhaust. From day 1 it was like that. until you run real hot. Then it drops you a ton.. Like to 12.5* <img src="gr_stretch.gif" border="0">
Old Jan 14, 2002 | 10:04 AM
02 'Hawk's Avatar
From about 4500 up, it's fuel curves not timing advance that will get you the power. That's the way ed does it anyway. Ed is getting ~345 with basically stock/minor bolt on LS1 cars. Info for informational purposes/discussion only.
Chris
Old Jan 14, 2002 | 06:09 PM
CWK's Avatar
CWK
My car is a 2000 z28 m6
mods are mac headers w/ofroad
borla catback
mti lid
asp underdrive
comp cams 224/224 568/568 112lsa
4.10 gears
hypertech programer (programmed)
160 stat.
stock desreened maf.
By the way I'm not getting any kr.
Old Jan 16, 2002 | 12:38 AM
blazinredls1's Avatar
dont know if this goes with the topic, but if u have a hypertech, and install the RFG tuning this will give you more timing correct? Then u can tune it with the maft to give you more hp correct? more timing more horsepower..
