electric water pump
Old Dec 11, 2006 | 08:18 PM
Quik's Avatar
Default electric water pump
is the metzler water pump worth it, i know the benefits but what are ppl's thoughts
Old Dec 11, 2006 | 08:34 PM
erikthegoalie's Avatar
its a piece of the bolt on puzzle for sure, but it is $$$
I have one...have not installed it yet...i chose to throw it on because it frees up parasitic loss through accessory belt drag...which will aid in faster revs and about 6-10 ponies, depending on tune...
If you have the cash, get it...but I would get other "essential" bolt ons before...LONG before...this is the last "bolt on" I have purchased...
Hope this helps
Old Dec 11, 2006 | 08:36 PM
btw this should be moved to external...youll get many more answers there...MODs, help this cat out..
Old Dec 11, 2006 | 08:44 PM
wht01ws6ta's Avatar
I assume you mean the Meziere water pump- I Just installed mine last week and have no complaints so far. I did notice an increase in power(SOTP)-actually surprised me how much but I guess the amount of power increase depends on the vehicle. It definitely keeps the engine a lot cooler; before the electric pump the coolest I could get the vehicle at idle was 171 at about 45 degrees ambient temp with both fans on and now it will go steadily all the way to 163 degrees and stops there so I think the thermo is closing at that point. I drilled the 3/16 holes into the thermo as suggested by Meziere to keep coolant constantly flowing to the pump so the engine does take somewhat longer to heat up now, but that is the only thing negative about installing the pump that I have noticed. I'm happy with mine
Old Dec 11, 2006 | 08:48 PM
wht01ws6ta's Avatar
Yeah move this down one notch
Old Dec 11, 2006 | 08:58 PM
Quik's Avatar
it woudl be a last "bolt on" its for my 408 project
sorry for wrong section if so have osmone move it for me
thanks
Old Dec 11, 2006 | 10:51 PM
exactly....if youre going to build a 408...i am assuming most of your concentration will be heads...cam...valvetrain...rotating assembly...you know the **** that moves the car haha...an EWP would be the "cherry on top"
Good luck buddy
Old Dec 11, 2006 | 11:04 PM
JRracing's Avatar
I'm very happy with mine. It was simple to hook up also. 10HP for 500 bones. Why not?
Old Dec 11, 2006 | 11:39 PM
TWISTEDTA's Avatar
Yea i was really considering on one too, but im going to wait to see how my new set up treats my 10 bolt...
Or ill wait till i have a really good month and just order one, but i think im over my limit for now since i still need tune.
