Question for heads/cam and/or stroker motor owners.
How many of you with heads and cam, or with a stroker notice your motor vibrates at RPMs quite a bit more, as if it's not balanced correctly?
Mine does, but the funny thing is, it doesn't do it all the time. Sometimes it's smooth, but I'll shift a few times and it's rough. Now you may be thinking Aha! There's your answer - the drivetrain, but it doesn't vibrate when I push in the clutch, only when the drive train is attached to the motor.
I had my motor dynoed and it's over 400 RWHP, and the dyno plot was really smooth compared with others that day that had very wiggly plots, so I don't think it's a cylinder not firing or a low compression problem.
I'm curious if it's just a normal manifestation of more power, or if there's a subtle problem that needs attention.
Anyone else notice this?
if it doesn't happen when the clutch is pushed it, could it be something having to do with the clutch disk or pressure plate? maybe something with the throwout bearing? cause then when the clutch is released and the gear is engaged, all those things start spinning again along with the motor. anybody have the same thoughts?
Chris
Chris
LS1Tech Co-Founder
Chris, the flywheel and pressure plate are always spinning with the motor, they are bolted directly to the crank. Its just the input shaft, disk, and drivetrain past the tranny that is not turning anymore when the clutch is disengaged.
Tony
Tony
Extra cam duration at the same lower rpm under a load will shake more from being less efficient in this lower range of use.
The vibration occurs at higher RPMs (> 3000) but only at part-throttle. Let's say I'm at 1/2 throttle and easily accelerating to 4000-4500 RPMs - thats the range where I get lots of vibration coming up through the floor, the tranny, and it even makes my rear hatch latch squeak. But it doesn't do this all the time, I'd say it does it about half the time. Its almost like I have a cylinder out, but when I go WOT, the power feels smooth.
Anyhow, seems like only a couple other folks I've talked with have experienced what I am so I'm starting to think I need to do a leakdown or compression test just to satisfy my curiousity. <img src="gr_stretch.gif" border="0">
Thanks again!
Dean
Thanks again!
Dean
