Engine temp
Old Jan 14, 2002 | 04:53 PM
2K2 LS1's Avatar
Default Engine temp
I always hear that the LS1 engine in general runs better when it is warmer. What I would like to know is if this is true; why does everybody do either the fan mod, turn their fans on earlier with the hypertech, and run cooler thermostats. Is it just a myth; or is there a specific temp that the engine runs best at? <img src="images/icons/confused.gif" border="0">
Old Jan 14, 2002 | 04:55 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Engine temp
My motor runs the best at the track between 170F and 180F, which is normal operating temperature.
Tony
Old Jan 14, 2002 | 09:18 PM
Ragtop 99's Avatar
Around 180 seems to be good. Problem is a stock T-Stat & fans let the temp go over 200 and a 180 T-stat normally has fans coming on at 192 - 194 degrees. Thus a lot of people use the 160 T-stat and fans that come on in the low 170s.
Old Jan 15, 2002 | 08:07 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
My car actually runs it’s best between 190 and 200. Above 200 and it starts to fall off a bit. I have a 180 stat and fan programming that keeps the motor around 195 at almost all times.
[ January 15, 2002: Message edited by: RPM WS6 ]</p>
