#30 injectors
Old Jan 14, 2002 | 08:12 PM
NOS powered LS1's Avatar
Default #30 injectors
what do i need to make the car not run rich if i buy some Accel #30 injectors from summit,,,will a MAFT work?
Old Jan 14, 2002 | 10:18 PM
Default Re: #30 injectors
ttt, i really need to know
Old Jan 15, 2002 | 08:45 AM
Warlock's Avatar
It depends on your mods somewhat but I understand that the PCM should correct your fuel/air mixture. If you have problems a MAFT should work fine. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Jan 15, 2002 | 08:50 AM
ONYXSS's Avatar
I think the right way would be to reprogram for the bigger injectors. Don't think the PCM will adjust on it's own. MAFT may work, but I'd change the PCM setting when LS1 edit is here.
