Just bought HPP3, what do I do with it?
Old Jan 15, 2002 | 10:10 AM
Wicked Ls1's Avatar
Default Just bought HPP3, what do I do with it?
What things did you all do to help you most effectively? Did you see a gain in rwhp or just at the track? Or neither?
I have:
99' Trans AM
A4
Corsa Exhaust
MTI Lid
Ported TB
Ported MAF
Thanks,
Jason
Old Jan 15, 2002 | 10:47 AM
Slow Z28's Avatar
Default Re: Just bought HPP3, what do I do with it?
i gained a little bit withthe power tuning and using good gas. you might see a little bit because of the little amount of mods you have. people that usually lose power are those that have heads/cam/stroker/etc....although, every car is different. that is something to test at the track. you could raise the rev limiter a bit and play with shift points. i gained about 3 tenths from diong that. don't mess with the shift firmness either cause at WOT, line pressure is at 100% anyways. hope this helps a bit. it is also useful if you do a gear swap or a wheel/tire change that is different than stock height.
Chris
Old Jan 15, 2002 | 11:21 AM
Wicked Ls1's Avatar
Cool.
Thanks,
Jason
Old Jan 15, 2002 | 11:52 AM
LS1LT1's Avatar
I saw no gains from the power tuning on my '00 Z28 but the fan setting (160* t-stat)/shift point/rev limiter changes certainly helped a lot. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Jan 15, 2002 | 01:38 PM
Wicked Ls1's Avatar
That is what I was thinking. In the manual it says something about only use "Power Programming (rgf?)" If you live in a state where something like reoxgynated gas fuel? is supplied. I don't think we have that here in houston. Not that I know of. That is suppose to be some high performance fuel. So if you use that setting your engine will expect alot better gas and since most of us only have 93octane we will get a crapload of knock.
-Jason
Old Jan 15, 2002 | 03:14 PM
Silver99Z's Avatar
I lost 7 hp with HPP power tuning, using 94 octane gas.
