LS6 intake questions
Are all non EGR manifolds LS6 manifolds?
Did 1997-2000 corvettes have EGR valves just like 1998-2000 F-bodies?
Are the part#'s on a 2001/2002 LS1 intake the same as the 2001/2002 LS6 intake?
there is a local junkyard with 10 wrecked vettes and 15 wrecked f-bodies and I thought I go check them out.
[ January 15, 2002: Message edited by: ws6rufus ]</p>
I can shift faster than you.
Yes, all LS6 intakes don't have EGR provisions from GM. The LS1 Corvettes did not have EGR as well since they had a different cam than the f-bodies (more overlap).
corvettes didnt have the EGR on the LS1s when the F bodies did.
If you look at the bottom of the intake, the LS1 will have a hump in the middle, where the LS6 will be flat on the bottom.
the jan issue of hot rod has a great pic of what im talking about
