pros/cons of running a bigger cam over a 224?
ok needed a re-map, he's done and the number are ..... A BIG DISAPPOINTMENT!!
411hp didnt get the tq numbers from him. This is thru a 9"with 3.89 gears on a mustang dyno. I'll post the graph tomorrow when I get it. He said it picked up more torque through the mid range than before.
Im going to install the same setup over Xmas break..
TR 224 cam with Ported 853 castings. 918's and Pushrods etc..
Whats the RPM recommended to spin this combo to... Its also an A4..
I was hoping to have close to 400 rwhp... and With the 3600 Fuddle.. Hoping to run some killer track times!
#32
The other way is time consuming and harder on the car... take it to the track and try different runs at different shift points per run. Too much error in that for me. But I suck at driving.
#33
Great street/strip cam. When i had an m6 i put down 428hp with mods in sig through a 9 inch and steel ds. After the auto it did 372 unlocked. I am switching to a customer grind (238/242,.600/.612/114lsa). This is only for the simple fact that good tuners can make big cam run great and produce slightly faster track times that the tr224. Why not?
#35
XFI Lobes 3015/3035 224/224 @.050 .609''/.600'' 110Lsa 108Icl 4*overlap
Ivo 4.0....Ivc 40.0
Evo 44.0......Evc 0
It would make a good street cam ,LS6 heads /.040 gasket , high dynamic compression for a simple combo .
Ivo 4.0....Ivc 40.0
Evo 44.0......Evc 0
#36
Originally Posted by N4cer
LOL! Don't you mean "custom grind" (instead of "customer grind")? LOL!
Not trying to be a ****. I just got this vision of every average schmuck walking into a shop and playing with the machines to grind their own cam.
But that would be kind of cool. Ya I'll have the grind of the day please..
#37
Originally Posted by Regginator
What part of KY/OH are you in? Im always out just cruisin around in florence.
