Can a water temp gauge be rigged to record tranny temp also?
I saw on the page below where he has an oil temp gauge rigged up to where you can push a button and it will show the trans temp. I was just wonderin if you could do this same thing with an Auto-meter water temp gauge. Just curious
http://xse.com/leres/ss/gaugepod.html
_Josh
_Josh
Re: Can a water temp gauge be rigged to record tranny temp also?
on saturns the trans temp sensor and the coolant temp sensor are the same part number. so yes it should be possible if i understand your question correctly <img src="images/icons/confused.gif" border="0">
Yup, I believe the 2 gauges are identical except one says Trans and one says Oil. In fact, the coolant temp one is the same as far as I know. I mean, they all do the same thing, measure the temp of a liquid. I couldn't see any diff between my trans and coolant temp gauges/senders.
Just installing a switch to switch between senders would be all you need, I think.
Dope
Dope
