What settings for the MAFT?
Old Jan 16, 2002 | 07:57 AM
DG Gordon's Avatar
Default What settings for the MAFT?
Where should I start with th settings. I want somewhere to start after my cam and headers are installed this weekend. I lost the paper for it, I used it on my 98 SS but need some help with this one. I will not have any tools to help with this so I would like everyones input. Thanks dg
Old Jan 16, 2002 | 09:43 AM
J&JsTA's Avatar
Default Re: What settings for the MAFT?
First off you need some readings/data to examine to see where your A/F, O2, and Ltrims are before you can make any adjustments. Some Atap runs are in order first, you may get real lucky and need no adjustments from your MAFT at all. <img src="gr_grin.gif" border="0">
Old Jan 16, 2002 | 11:26 AM
NASSty01's Avatar
First you want to dial your BASE setting in. Start at 0/0 and ATAP. Make an adjustment, put about 50 miles on it and ATAP again. When you get your BASE setting where you want it, then dial in your 02's. 02's you don't really need to put 50 miles on each adjustment. The BASE setting takes time for the computer to re-learn.
Doing it this way, got me from 20* w/3*KR peak timing to 28* w/0 KR. And I've got some more ATAPing to do. Just waiting for some decent weather.
MAFT tuning is unfortunately not something you do in an hour or two.
And like he said, if your lucky you won't need any adjustments. <img src="gr_stretch.gif" border="0">
GL
Rick
Old Jan 16, 2002 | 11:56 AM
J&JsTA's Avatar
Hey Nassty, do you know if resetting the ECM will speed that relearn process up any or will it make any difference at all?? <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
