PCM programming with cam / converter????
Old Jan 17, 2002 | 08:11 PM
Ram Air Tony's Avatar
Default PCM programming with cam / converter????
to the PCM gurus <img src="gr_stretch.gif" border="0">
I am going to swap the LG cam (.574/.581, 224/230, 112 LSA) along with Yank ST 3200 and Hooker's new LOng TUbes headers.....I am getting custom PCM work ...... what should I get as in shifting points, firmness ???, converter lock up???? fans on at 180 (yes), fuel and timing (up to the PCM guy), delete rear O2's
what else??? I need a list of what to do
thanks
R
A
T
Old Jan 18, 2002 | 08:04 AM
Ragtop 99's Avatar
Default Re: PCM programming with cam / converter????
I'd shift around 6400 rpm with a stock bottom end and tranny. 6800 rev limiter. Put a 160 T-stat in and fans set to match.
Delete torque management, AIR & EGR codes too.
I'd raise converter lock-up speed to 40 mph.
Old Jan 18, 2002 | 08:33 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You'll definitely want to delete misfire codes, and it wouldn't hurt to have them delete the maxed out MAF code. With that size of a cam in stock cubes, an idle at 900-950 will help out, too.
__________________
Old Jan 21, 2002 | 10:59 AM
thanks for the tips guys....
I got a LONG list between here and LS1
thanks
R
A
T
