Check these install prices? (please!)
Prices below:
The frame connectors will be about $250 to $350
install depending on type and brand.
The suspension work (springs and shocks/struts) should be about $275
The pulley will be about $35
Now I thought this looked pretty good except for the subframe connector. I emailed the shop back to ask what that included (taking out interior etc.) but I never heard back.
Do you thinks this is reasonable?
Sounds to me like they do not know what they`re doing...
Welding in subframes shouldn`t be more than $75.
Shocks/struts.. I know a place that does it for $150.(if I bring in parts)
Pulley price is too low for a shop... I don`t think they know whats involved.
I had the following installed for $115:
SLP bolt on subframes
SLP Rear LCA's
SLP Panhard Rod
1LE front and rear sway bars
Hotchkis Shock Tower Brace
I was quoted $480 to $250 by other sources.
Shop around if they want that much for subframes.
SLP Rear LCA's
SLP Panhard Rod
My muffler guy welded in BMR sub frame connectors and than primed & painted the weld areas for $50.
No need to remove anything from interior. Welding didn't bother carpeting.
Can't remember what he charged to install four springs and four shocks, but it wasn't nearly $275. It was somewhere around $100 as I recall.
Most importantly, this shop does first class work.
Most muffler shops will weld the sub-frames for $50 to $75.
I don't know about the springs and shocks, cause I installed them myself.
The pulley is harder than they estimate. <img src="gr_images/icons/cool.gif" border="0">
Check around! You should be able to have all those done for less than $200. Good luck! <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
[quote]Originally posted by thefritz1:
<strong>Prices below:
Do you thinks this is reasonable?</strong><hr></blockquote>
RUN don't walk to another shop!!!
