LSA seperation and the SES light
The reverse is also possible, with the air/fuel mixture backing up into the intake manifold because of the back pressure in the exhaust, setting a lean code and possible cause some pinging.
The increased overlap will also cause a rougher idle and possibly set a misfire code.
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Solution: If you're going to go without programming for any significant amount of time (which I have, I'm on 5+ months and counting) just be careful about how long you let the car idle. Don't let it idle at the same RPM's for more than 30-60 seconds. If you get stuck in traffic, a gentle throttle blip (no more than 1000-1200 RPM's) will prevent the code from popping up. I haven't seen the SES light in months.
<strong>A cam with a tighter LSA will have more overlap area (intake and exhaust valves open at the same time). This increased area will do several things. First of all, with the intake and exhaust valves being open at the same time for a longer time, more unburned fuel makes it into the exhaust, possibly setting an SES light (too rich).
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" /> </strong><hr></blockquote>
does the cam you get determine whether you get a rich or lean mixture? and to avoid this do you get a MAFT or custom programming? I am curious because i dont want to get either of these to act as a sort of "cover up" for the rich/lean mixture causing long term stress without heads or anything. Which would you guys get and what have you guys with a stock motor and cam have?
Tighter LSA will make more mid and just off low end tq than wider one.
Tighter LSA will mean the intake valve will be open further during strongest portion of the induction cycle.
<strong>YOu guys make a tight LSA sound like a lose-lose for everything.
Tighter LSA will mean the intake valve will be open further during strongest portion of the induction cycle.</strong><hr></blockquote>
That wasn't the original question, though.
<img src="gr_images/icons/wink.gif" border="0">
'Los
<strong>
does the cam you get determine whether you get a rich or lean mixture? and to avoid this do you get a MAFT or custom programming? I am curious because i dont want to get either of these to act as a sort of "cover up" for the rich/lean mixture causing long term stress without heads or anything. Which would you guys get and what have you guys with a stock motor and cam have?</strong><hr></blockquote>
It can be anything from the cam specs you chose, to the way those specs were ground (fast vs. slow ramps), to the way it is installed (advanced vs. retarded). The most likely event has already been mentioned...random misfire codes. Get Autotap if you can or have a friend ATap your car when you get an SES light. If it is a misfire code, it is very common and probably not harmful.
'Los
