Whats the best year LS1 in an Fbody??
They have:
LS6 intake, stock. ('01 and up)
No EGR ('01 and up)
Bigger fuel tank (vs. '98s smaller one)
better exaust manifolds and cats ('00 and up)
bigger injectors like the '98s
"possibility" of getting LS6 heads like some of the '01 models got (production overrun)
2nd gear start mode for Automatics ('00 and up)
torquier cam ('01 and up)
Only bad thing about '01 and '02s are the tighter pcm regulations and increased torque management.
I like the '98s from a performance per value standpoint, but from a completely stock standpoint, the '01s and '02s are the best of the lot.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
<hr></blockquote>
Patrick G, how can one tell if they have the LS6 heads on their 2001 car??
[ January 21, 2002: Message edited by: MrTransAm ]</p>
<strong>'98 were made with bigger injectors and a bigger fuel pump, also a less restrictive manifold. Perfect for nitrous. But also the '01-'02 LS6 intake manifold makes a nice addition.
[ January 21, 2002: Message edited by: MrTransAm ]</strong><hr></blockquote>
In 2001, GM went back to the larger injectors on the LS1s. The 98 fuel pump is higher capacity, but I am not sure what manifold you are talking about. Both the intake manifold and the exhaust manifolds are more restrictive than the 2001 + intake and the 2000 + exhaust manifolds. The double wall of the 98-99 exhaust manifolds puts a very serious restriction in the manifold and the Y-pipe is much more restricted than the 2000 + version.
Todd
<hr></blockquote>
Bahwaahh?? <img src="gr_eek2.gif" border="0"> <img src="gr_eek2.gif" border="0"> This is the first i have heard of this. Could you explain why GM did that? How many are out there? Are they still doing that?
I am curious because i just ordered an 02 and it will be here in about 3 weeks. I would be the happiest guy in the world if i got some LS6 heads on it from the factory.
<strong>Best year is '02 as far as total performance and least amount of "bugs". GM always puts out the best product the year they kill it, LOL. '01 would be equal.
They have:
No EGR ('01 and up)
I like the '98s from a performance per value standpoint, but from a completely stock standpoint, the '01s and '02s are the best of the lot.</strong><hr></blockquote>
What type of bugs are associated with the 98's?
Can you delete the EGR on a 98 with HPP3, LS1 edit, or something similar? So the 98's show greater gains when switching to a LT header/off road y pipe than the 2000 and up cars? If you do remove the egr system from a 98 car, do you still order 98 Headers???
The 98s were manufactured with thin wall cyl sleeves that will not except more than a .005" cyl hone (no boring machine bar). Sometime during the 99 production year, the sleeves were re-designed so as to be able to except a boreing bar up to (I believe) .020" cut
This may not present a real problem for most, but just remember; You aint going to bore the 98s.
And, like I stated; Some very early 99s have the same thin wall sleeves as all 98 (and all 97 Corvette LS1 motors).
Ron,
98 TA
<strong>The 98s were manufactured with thin wall cyl sleeves that will not except more than a .005" cyl hone (no boring machine bar). Sometime during the 99 production year, the sleeves were re-designed so as to be able to except a boreing bar up to (I believe) .020" cut
The new sleeves can go 0.010
<strong>LS1 cylinder head casting numbers are easy to find and read, can any one tell us ls6 3digit casting #'s?</strong><hr></blockquote>
I would like to know this also if anyone has this info. <img src="gr_stretch.gif" border="0">
If cost wasnt an issue? 2001-2002.
The 98's had stainless steel exhaust manifolds that could be ported. Larger injectors, etc, etc.
The down sides to the 98 would be the HPP3 adjusting the shifts by MPH and not RPM. (That sucks)
The tranny programming is VERY aggresive in the 98's. In the later years the Torque magt. gets to be very intrusive. It pulls out to much timing for me. 98's tend to be able to run LOTS of timing with no problems. (IMO)
Are the 2002's coming with different (stronger) head gaskets?
Man I like the 2002's...
FWIW, my 98 ran 115 traps with a completely untouched motor, unported Mac headers, stock granny gears, timing problems, and a slipping clutch. Guess they ain't so bad eh? <img src="gr_images/icons/wink.gif" border="0">
Josh
