PTV Clearance
Old Dec 16, 2006 | 02:56 PM
Ls1Envy's Avatar
Lightbulb PTV Clearance
I'm about to install a 230/232 114 comp xer along with AFR 205's milled .024 w/ .040 gasket. I'm a little worried about the clearance. People have said I should be fine. But If I had a little more reassurance I could quit stressing about it. Is anyone running this cam or similar with the milled heads and thin gasket?
I would like to check the clearance but I don't really know what I'm doing.
Old Dec 16, 2006 | 04:22 PM
JPH's Avatar
JPH
yes diffently close, but should clear. question is, will it be safe clearance? only one way to know, check it.
Old Dec 16, 2006 | 04:48 PM
Ls1Envy's Avatar
Right, checking it. Yeah, I guess I could do that if I knew how. All of the instructions I have seen are very vague to me. I'm very inexperienced.
Old Dec 17, 2006 | 01:54 PM
Ls1Envy's Avatar
Is there a method where you do not have to use a solid lifter and checking spring? I already have the push rods I am going to use.
Old Dec 17, 2006 | 10:22 PM
bigdsz's Avatar
I've got a Comp XER 228/230 with unmilled heads and I had to fly cut, I only had .045 clearance. You don't say what size valves. A search will tell you how to check PTV. Also it's a good idea to clay. I think Tony Mamo has said a number of times to notch with anything bigger than a 224/228.
Old Dec 18, 2006 | 12:16 AM
N4cer's Avatar
Search for the clay method. And yes, needs a solid lifter. Or an old lifter that you make a solid just for mock-up purposes.
Old Dec 18, 2006 | 03:57 AM
Ls1Envy's Avatar
You also have a 112 LSA which makes things a bit different. I've read a few guides on the clay method, but don't feel confident that I understand it all.
Old Dec 18, 2006 | 08:36 AM
JRracing's Avatar
Go buy one lifter to use for this or buy a new set and use one of the old ones and weld it up. Actually you should do two of them like this. That away you can check one cyl on int/ext. Use modeling clay from a craft store.
Old Dec 18, 2006 | 08:39 AM
JRracing's Avatar
Heres what mine look like after fly cutting.
