Comp Cam 918 spring + 772 Retainers = TIGHT fit?
For those that installed there Comp Cam 918 Springs along with the Comp Cam 772 Ti Retainers were the retainers a tight fit on the springs?
We just got our springs and retainers yesterday. While placing the retainers on the springs, we noticed the fit was kind of tight. Comp Cam said this was normal and to use sand paper on the retainer if needed. Any input?
Thanks,
Teddy
[ January 23, 2002: Message edited by: Teddy98Z28M6 ]</p>
Thanks,
Teddy
Re: Comp Cam 918 spring + 772 Retainers = TIGHT fit?
When the 772s first came out they were actually a loose fit. Shortly after that they were modified to fit better (tighter) with the 26918s. So yes, I would imagine that this tight fit is in fact normal.
Comp cam was saying a tight fit is what you want (I agree), but I'm not sure about having to sand the retainers. I think for the price of these components, you shouldn't have to sand anything. The Ti retainers do fit perfectly on the stock LS1 springs from what my friend said.
I believe the tightness is from the 918's top coil. I'll have to post some pictures when I get some pictures.
I didn't have to sand/grind anything on mine, but they did take some pressure to get them to snap into place.
I've seen engine builders forced to resort to using a bench vise to snap retainers on valvesprings before.
I took some pictures tonight and got all the Ti retainers to fit on the 918 springs. 7 Ti retainers fit the 918 springs with slight pressure. 4 retainers I sanded slightly with fine sand paper and applied with some hand pressure. 5 fit with no sanding and lots of hand pressure.
Here's the pictures.
Stock 98 spring on the left and the beefy comp cam 918 on the right.
Stock 98 retainer on the top and light weight slightly larger diameter Comp Cam Ti retainer on the bottom.
The stock spring with Ti retainer on the left (good fit but slightly loose). 918 spring with the Ti retainer (doesn't fit without pressure).
The stock spring with stock retainer on the left (good fit but slightly loose). 918 spring with the Ti retainer (not loose and very snug fit).
[ January 24, 2002: Message edited by: Teddy98Z28M6 ]</p>
I sure would like to see those pics. Here is what I get when I try to open any of them:
_____________________________________________-
Forbidden
You don't have permission to access /c5/2002ebz06//cc1.jpg on this server.
Apache/1.3.14 Server at temp.corvetteforum.net Port 80
______________________________________________
What do you suppose is wrong here. Never had a problem with other pics.....?
Forbidden
One more picture.
A stock 1998 spring with stock retainer on the left. A 2002 LS6 spring with the stock retainer in the middle. The new Comp Cam 26918 spring with the new Comp Cam 772 Ti retainer on the right.
If you cut and paste the link into a new window it will work. Corvetteforum is doing the yahoo thing. <img src="images/icons/rolleyes.gif" border="0">
I'm going to host the pictures somewhere else in a few mintues.
[quote]Originally posted by wot247:
<strong>hey george, if you dont mind me asking, what happend to your motor? did it just let go? or a defect? thanks.</strong><hr></blockquote>
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=5&t=000451
That should pretty much explain it all... Looks like a rod bearing may have spun, then frozen up, causing the rod to break...
I should have the car back home next week, and have the motor out of it shortly thereafter to find out exactly what went wrong.
Trevor, the LS6 spring came from an extra set of '02 LS6 heads. No cam change in the Z06. If I race on the 2nd it will most likely be in the Z28.
Eric, the stock retainers will work with the 918's. I got the 772's because they are lighter and stronger.
[quote]Originally posted by Damian:
<strong>So stock locks and retainers can be used with these springs?</strong><hr></blockquote>
Yes. 772s will probably premote longer spring life though...
