Growling Power Steering Pump
Old Jan 23, 2002 | 05:31 PM
Jax White TA's Avatar
Default Growling Power Steering Pump
It seems to make a growling noise when idling along and if you apply some pressure to the wheel, you hear it get louder. Its not eating fluid and the steering feels fine. What could it be? There's always been plenty of fluid too so I dont think air could've got in there.
TIA,
Dan
Old Jan 23, 2002 | 07:07 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Default Re: Growling Power Steering Pump
The steering rack is probably about to take a dump.
Old Jan 23, 2002 | 07:11 PM
Oh great. Have you seen this before? I thought it might be the power steering pump itself. <img src="images/icons/confused.gif" border="0">
[ January 23, 2002: Message edited by: Jax White TA ]</p>
Old Jan 23, 2002 | 07:47 PM
Also, if it goes out when I am driving, doesnt that mean I will lose total control of the steering?
Old Jan 23, 2002 | 08:19 PM
Crazyquik's Avatar
Hmm, mine makes a little bit of noise, maybe its cause I've boiled the fluid twice <img src="graemlins/gr_angel.gif" border="0" alt="[angel]" />
Old Jan 23, 2002 | 10:25 PM
It happened to me with my 96 Z28. It will just get louder. Try swapping the fluid for synthetic P/S fluid and see what happens.
[ January 23, 2002: Message edited by: Richie Carbone ]</p>
Old Jan 24, 2002 | 06:35 AM
Thanks guys. I'll try the synthetic. I also have a power steering cooler I bought but never installed. I guess this would be a good time to do that. I would imagine it just goes inline after the rack before the pump right? Is there install instructions for the LS1 anywhere?
Dan
Old Jan 24, 2002 | 11:56 AM
WFO_SS's Avatar
f-body p/s pumps ALWAYS make slight groaning noise when turning wheels @ idle speeds, especially with your foot on the brake. unless it is extremely loud and/or only does it in one direction, i wouldn't worry about it.
Old Jan 24, 2002 | 01:36 PM
I've had this car since 1999 and put over 40K miles on it. It has never been this loud. You can hear it over my C1 cam and SLP headers, ORY, running out the cutout. Yeah, I'd say that's loud.
Old Jan 24, 2002 | 01:40 PM
WFO_SS's Avatar
one direction or both?
all rpms?
less assist since noise started?
Old Jan 24, 2002 | 01:47 PM
It can be heard just sitting there idling by not even touching the wheel. Sometimes it will stop, but can be started again by turning the wheel a bit either direction. The assist amount has not changed. It still steers just fine. I honestly cant say if it continues through the entire RPM range because the car is so loud.
Old Jan 24, 2002 | 03:47 PM
Fletch's Avatar
My 98 does this. Well it doesnt growl, but it whistles. It does it when I turn the wheel at idle and when I'm making a low speed turn like turning right or left at an intersection. I figure the whistling is normal, if I'm wrong can someone correct me?
Old Jan 24, 2002 | 04:09 PM
Beth's Avatar
My 98 began getting noisy and continued to get louder turning either way. It would moan as if I had the wheels turned all the way to one side. The Dealer replaced the pump under warranty and now I hear nothing at all. Not sure about a whistling.
