SI3 cam?'s
Old Dec 18, 2006 | 10:28 AM
02NHRAtransAm's Avatar
Default SI3 cam?'s
224 224 .581 .581 114
Thinking of going with this cam.
Which valve springs/ pushrods would u guys recommend for
this application??
Old Dec 18, 2006 | 10:29 AM
Sudz's Avatar
patriot golds, or prc duals. which ever you find cheapest. or look for sponsor sale items.
Old Dec 18, 2006 | 12:23 PM
what should i expect hp wise w/ this cam??? (Im thinkin a little under 400rwhp)
Old Dec 18, 2006 | 04:53 PM
t t t
Old Dec 18, 2006 | 06:02 PM
Oh4GTO's Avatar
Dont go duals with that cam. Beehive springs are much better. They dont surge like conventional springs and provide better valve train stability. Comp 918s are good for .600".
Old Dec 18, 2006 | 06:34 PM
i was actually looking into the comp 918's
Thank you fo your feedback!
Old Dec 18, 2006 | 08:34 PM
mvvette97's Avatar
patriot Golds I wouldn't trust a single spring with that lift. I run the max of 573 lift and had some 918s break. I was lucky a valve didn't drop. Duals are the safer way to go.
Old Dec 18, 2006 | 08:55 PM
black01_WS6's Avatar
918's are fine for your application. when they came out with the dual spring they lowered the lift rate of the 918's to .600 from .625- spring is the same. Just keep an eye on the mileage on the springs and check them every now and then- you should be doing that with aftermarket springs.
as far as pushrods go the 7.4's would be the ones you would need.
Old Dec 18, 2006 | 10:19 PM
Tom@SpeedInc's Avatar
We have a hand full of LS1s running SI3 with 918 springs. Good street manners with that cam too.
Old Dec 19, 2006 | 11:22 AM
thanks for all the feedback guys
