FTRA
Old Jan 25, 2002 | 02:58 AM
AlonzoVersion 1.0's Avatar
Default FTRA
I was thinking about getting one but sense I dont have an air deflector piece then I wouldnt be able to use the bottom plate.I already have the fra mod but was wondering if I would gain any just by using the upper portion of their kit.The car has no ac cause well its a beater but a nice looking one he he he.Any input is very grateful thanx.Time for the spinarune. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 25, 2002 | 08:04 AM
Ragtop 99's Avatar
Default Re: FTRA
Are you sure you have no place to attach a couple screws on the bottom plate or rig something up? <img src="images/icons/confused.gif" border="0">
The upper part helps, but the lower plate really makes the set-up work.
Old Jan 25, 2002 | 09:36 AM
Default Re: FTRA
[quote]Originally posted by Ragtop 99:
<strong>Are you sure you have no place to attach a couple screws on the bottom plate or rig something up? <img src="images/icons/confused.gif" border="0">
The upper part helps, but the lower plate really makes the set-up work.</strong><hr></blockquote>All I have is my radiator up front.I am not sure if I can rig anything together though.Thanx for the info and for helping me choose my converter as well.Let me know if you can come up with something.
Old Jan 25, 2002 | 10:14 AM
Supertrapped's Avatar
Speed freak
Default Re: FTRA
Even though you don't have an air-deflector peice, the bolt pattern should still be there, so you can still install the bottom plate of the FTRA. If, for some odd reason, there isn't a bolt pattern going across where the air-deflector used to be....you can always just use the radiator bracket.
Old Jan 25, 2002 | 11:18 AM
Fast Toys Performance Parts's Avatar
Default Re: FTRA
Booker man,
The holes to mount the lower plate will still be present on the car. However, I would be seriously concerned that you do not have that lower black air deflector on the vehicle. This piece is what routes air into the radiator for proper cooling. Without it, your cooling system will suffer and you could risk overheating.
Old Jan 26, 2002 | 12:06 AM
Default Re: FTRA
[quote]Originally posted by DevilBird:
<strong>Even though you don't have an air-deflector peice, the bolt pattern should still be there, so you can still install the bottom plate of the FTRA. If, for some odd reason, there isn't a bolt pattern going across where the air-deflector used to be....you can always just use the radiator bracket.</strong><hr></blockquote>Thankx for the heads up and heres a spinarune for you
Old Jan 26, 2002 | 12:07 AM
Default Re: FTRA
[quote]Originally posted by Fast Toys Performance Parts:
<strong>Booker man,
The holes to mount the lower plate will still be present on the car. However, I would be seriously concerned that you do not have that lower black air deflector on the vehicle. This piece is what routes air into the radiator for proper cooling. Without it, your cooling system will suffer and you could risk overheating.</strong><hr></blockquote>You are correct about the heating problem.I thank you for the heads up as well and for making an excellent product.Heres a spinarune for you.
