E85 internal engine pics
Old Dec 19, 2006 | 12:01 PM
rubbersidedown's Avatar
Default E85 internal engine pics
enjoy- to dispell some myths
http://www.rune85.com/internal%20engine.htm
Old Dec 19, 2006 | 04:41 PM
No Juice's Avatar
Nice!
Old Dec 19, 2006 | 05:12 PM
GuitsBoy's Avatar
Very nice to see!!!
Old Dec 24, 2006 | 01:04 PM
JUSTIFIED C5's Avatar
Very impressive pics, nice to see.
Old Dec 24, 2006 | 01:12 PM
hammertime's Avatar
How the heck does that work without a fuel composition sensor and the appropriate Air Fuel ratio. Still, looks good!
Old Dec 24, 2006 | 01:21 PM
SS4Matt's Avatar
i just did a pretty big speech for a final in one of my classes on flex-fuel. from what i found researching it was the reason why it's not good for "non" flex-fuel vehicles is because the ethanol is corrosive on rubber parts and some aluminum parts. other then that, it's just higher octane (about 105) it's still 15% petroleum so that's what helps save a lot of the parts...hence E85 (85% ethanol 15% petroleum)
kinda cool to see they ran that for that long with little problems though. mostly the injectors pump and lines take the "beating" from the ethanol.
Old Dec 24, 2006 | 05:03 PM
black_z's Avatar
Most OBDII cars fuel system components will handle the E85 just fine, the corrosiveness of the fuel is just propaganda spewed by big oil. We test E10, E20, E50, and E85 at our school pretty extensively and the corrosion is pretty much non existant on newer vehicles.
Old Dec 24, 2006 | 05:42 PM
3.4camaro's Avatar
wait, so E85 is higher octane and keeps the engine cleaner?
Old Dec 24, 2006 | 05:53 PM
black_z's Avatar
Yes, it will also cool the intake charge.
Old Dec 24, 2006 | 06:57 PM
GR33N GoblinM6's Avatar
but what about the things said about having poorer gas mileage? I keep seeing that all the time
Old Dec 24, 2006 | 07:04 PM
Red99TA's Avatar
E85 has a lower energy contect per gallon than regular gasoline. As a result you have to put more E85 into each cylinder than gasoline to achieve the same power output. This is what causes the decreased gas mileage.
Old Dec 24, 2006 | 09:25 PM
SS4Matt's Avatar
i can't wait till E85 is "developed" more and is more easily found. it is definatly a great energy alternative for us gear heads...sure beats the hell out of my moms panzy *** 1/2 electric Prius bullshit!!
Old Dec 25, 2006 | 01:02 AM
WS6GoFast's Avatar
so what exactly has to be done to run e85 in our cars?
Old Dec 25, 2006 | 07:24 AM
Runn's Avatar
Lots of info in this thread. https://ls1tech.com/forums/fueling-injection/602091-how-run-your-ls1-e85.html
