HELP!! Is my engine FUBAR???
I am getting some blow- by out of the breather on the valve cover and if I remove the oil fill cap and rev the motor it will puff out of the filler.
I have seen this before on my vortech blown Impala SS and it was the tell tail sign that my engine was fubar!!!
I have not sprayed the car or ran a blower on it. I recently had it dyno tuned and it put down 374 to the wheels. I have boltons and a 218/224/114 comp cam.
Is my engine FUBAR??? Is it the rings? or could it be the valve guides or valves? Thanks.
Brad
cyl. press leak down test is in order. also, does it puff smoke on start up, then quit? if so valve guides or seals. Just a thought
[ January 29, 2002: Message edited by: zombiedude ]</p>
It does not smoke out the tail pipe under ACCELERATION, but will under DECELLERATION. I disconnected the PCV because it was sucking oil and making smoke. However, it still smokes a little.
thanks for the reply. That is interesting. Can you explain a little more? I am asssuming that you have a PCV on yours, how are you keeping from sucking oil out the valve covers? I was thinking about relocating the PCV to the top of the oil fill cap to get it out of the line of the oil.
Thanks
I tried running just the LS6 pcv system and it ended up being too much crankcase pressure. I am running a breather on the driver's side and half of the passenger side pcv system. Not ideally what I want but I am assembling parts to the evac kit.
did/do you ever have smoke/steam/stuff comming out of either breather? That is my biggest concern. I will be bringing it in for warrantee soon so I will have them run the necessary tests. If the engine needs to come appart, it will be put back together with ported and polished heads and a new cam.
Franco said that the rings are often stuck because of the nast carbon deposits on the tops of the cylinder and in the combustion chamber.
That is why I am so concerned about the puffing valve cover. I will be bringing it in soon.
