I have a rattle sounds like the clutch
Old 12-20-2006, 07:28 PM
REDSS98's Avatar
Default I have a rattle sounds like the clutch
Ok I have a 98 SS and when you push in the clutch it and put it in gear it rattles. But it does not jump or any thing like when most of you clutches are going out. when you sit in gear and clutch pushed in it rattles when not in gear it does not. Could it be the bearings in the main shaft in the trans.
Old 12-20-2006, 07:32 PM
kenp's Avatar
It doesn't rattle when in nuetral with the clutch pedal depressed, but it does rattle when in gear with the clutch pedal depressed?
Old 12-20-2006, 07:47 PM
REDSS98's Avatar
No it does not rattle when in nuetral any pushed in only when it is in gear
Old 12-21-2006, 03:58 PM
kenp's Avatar
Best case scenario, it's a bad pilot bearing. If it were the bearings in the transmission, wouldn't it be more likely to make noise when in neutral w/o the clutch pedal depressed?
